WIN-PAK 2.0 question (new PC migration)
Steve
We've been running WIN-PAK 2.0r3 on an old PIII for nearly 5 years, and
I'm in the process of migrating it to a new PC.
The installation of WIN-PAK 2.0 on the new box went just fine, along
with the migration of the SQL databases. Now, before I officially
"cutover" to the new PC, I assume the last important step is to change
the Comm Server's machine name to point to the new machine name. BTW,
the Comm Server consists of (1) C-100 loop which contains 8 panels.
Should I disconnect the serial cable from the old PC, connect it to the
new PC and then update the "machine name" setting for the Comm Server?
Please let me know if that sequence will work and if I'm missing
anything else.
Thanks in advance.
Petem
Steve
have you recover the back up from the old machine?
if so you are ok, you just need to reconnect the serial cable to the new
machine and change the new machine name to what the old machine was named
before,its easier then changing the name in the database,and since the old
machine will surely be gone soon it wont matter in the network..
don't be afraid to connect the cable to the serial port ,it won reload the
controller cause you need to do it manually...
