Wind Generators combining
BarNash
Hi all
Ho can I combine the electric power output from 2 wind generators to
generate 1 voltage that is the sum of the 2 generators ?
This combined voltage will be the input to a DC > AC inverter that will
produce constant AC voltage
110 VAC for example .
BarNash
BarNash
I want to design the electronics that will combine the voltage from 2 wind
generators and feed the DC > AC inverter
charging bateries with that combined voltage will be done as well for
preserving power when the inverter is OFF .
I need the desription of the voltage combiner electronics design and from
there I will take it myself.
Eliahu
Paul Keinanen
Is there a specific reason why you can not connect these generators in
series ?
Are these generators producing several kilovolts and the insulation of
the upper generator is not sufficient. If that is the case, why not
ground the midpoint ?
Paul
