Winding a conventional AC line frequency transformer
Eeyore
It seems to have been my destiny in life to have to learn more about
transformers (and wind a fair few by hand) than I ever suspected I'd need to.
I learnt quite a bit about switchmode type transformers - I suppose actually you
could consider flyback types more like tapped inductors actually - from various
application notes and also here. Epcos's Ferrite Designer application is
additionally an excellent tool for pumping in the numbers for a wide range of
cores in various materials.
It so happens I'd like now to apply some of the techniques I've learnt to
traditional line frequency transformers.
I have several specific things in mind.
A. Reduced flux operation. Notably with toroids this can avoid the typical
'switch on surge' and it also occures to me that stray flux will be reduced both
in proportion to the reduction in magnetisation force and additionally because
operation at lower flux levels keeps core permeability values higher.
B. Improved coupling by using bifilar windings with triple insulated wire
eliminating the need for traditional insulation barriers.
C. Higher than 'typical' VA ratings for a given core size by using more
copper. Again this works well with toroids.
D. I'm sure there was something else but now I've forgotten.
The trouble is that I don't know of any single source of data on cores that's
comparable to the Epcos Magnetic designer. And then again, you can wind almost
any size core you like for toroids which will be my main area of interest.
Suggestions ?
Graham
Phil Allison
"Eeyore"
typical
reduced both
because
** Inrush surge will only be eliminated by doubling the number of turns on
primary and secondary.
Equates to using a 480 volt tranny on 240 volts - results in only half
the normal VA rating.
wire
** Completely absurd for a 50/60 Hz supply transformer where high
frequency coupling has no benefit.
** Fan cooling works to add VAs too.
** Exotic core materials ???
Increased VA to size ratio.
.......... Phil
Eeyore
Phil said:
"Eeyore"
A true 200% doubling is only necessary if the comparison transformer is already
operating on the edge of saturation.
Only if you stick to using the same amount of copper. I regularly 'overwind' to
reduce losses and gain VA rating.
It's also possible to use higher temperature insulation if you're pushing for VA
of course.
And the harmonics ?
It certainly would do but I'd like something that's not noisy.
Could be interesting.
Always useful.
Graham
Phil Allison
"Eeysore Fuckhead "
already
** How tediously pedantic.
This utter fool does not want not want anyone's input.
** Which is the whole point of the comparison.
for VA
of course.
** At the expense of output voltage regulation.
With a wire temp of say 150C, winding resistance and hence peak IR drop
increases by 50% over the room temp value.
And the harmonics ?
** Yawn ..........
Another Graham Fuckwit Stevenson contextless & meaning free question.
** So YOU go invent it and patent it - fuckhead.
This PITA fool REALLY does not want not want ANYONE's input.
** Do a Google search on it - fuckwit.
........ Phil
Paul E. Schoen
to.
actually you
various
range of
typical
reduced both
because
There is also a switch-on surge caused by remanent magnetism in the core,
which depends on the net DC current caused by odd number of positive and
negative half-cycles. It can be reduced by reducing the applied voltage at
turn-off, or using soft-start turn-on techniques. Another helpful method is
a capacitor or RC snubber on the primary which provides a damped
oscillating current path at turn-off. Toroids also exhibit this, at least
the ones I use in our high current test sets.
wire
Bifilar windings are most useful for primaries used in parallel, to
equalize the current. Secondaries are coupled very well because the flux is
concentrated in the small hole in the donut.
more
Toroids exhibit the best VA/weight and VA/volume because of the efficient
tape wound steel core, typically made with high quality and very thin
material. The core is very easy and inexpensive to make. Adding the
windings is expensive, because it is labor intensive, requires special
machines, and is difficult with heavy wire. Most of my secondaries are made
of bus bar, so the difficult part is completing the turns outside the hole
of the core.
The size of the hole determines the size of the copper windings, and is
also where the most heat will be concentrated. The outside windings are
well separated and more easily cooled. I am experimenting with a fluid
cooled design that runs thick wall copper tubing through the toroids.
that's
almost
interest.
Suggestions ?
Graham
A good source of information is www.toroid.com. They have toroid kits from
about 50 VA up to 1400 VA. The primaries are already wound on the core, and
you add the secondary according to their design charts for selecting number
of turns and wire size. Volts per turn varies from about 0.1 to 0.7. They
also supply mylar tape for insulation, and steel washers and rubber
bushings for center hole mounting.
You can also use old Variacs or Powerstats as toroidal primaries. They tend
to have larger than usual holes, so you can wind more copper on the
secondary. Some of them are as large as 5 kVA. They have tapped primaries
for 120/140 VAC, or 240/280 VAC. The higher taps can be used for lower
primary current on 50 Hz.
There are also some toroidal transformers that are wound with steel wire
cores, which are supposedly even more efficient. Tape wound toroids have a
rectangular cross section, but a true toroid has a round cross-section,
which can be achieved with wire. I would think there would be more wasted
space, however.
Good luck. Let us know what you are trying to do, and what results you get.
Paul
Robert Baer
Suggestions ?
Graham
I have info only on "E/I" and "C" core shapes (silicon steel
laminations), nothing on toroids (sorry).
Robert Baer
*Incorrect!* The flux is concentrated by the magnetic material - in
this case the body of the toroid.
Go back to a magnetics class...
Paul E. Schoen
If you are picking nits, you are correct. Perhaps it is better stated that
the location where a conductor will be most influenced by the magnetic flux
in the core is concentrated in the hole. Or perhaps I should have said
magnetic field, rather than flux. In any case, the point I was trying to
make is that the conductors within this relatively small space have current
induced in them only there, and it is a much smaller space than that of an
equivalent size EI core.
There is no need to be condescending.
Paul
Phil Allison
"Paul E. Schoen"
"Robert Baer"
** He ain't nit picking.
Perhaps it is better stated that the location where a conductor will be
most influenced by the magnetic flux in the core is concentrated in the
hole.
** Utter bollocks.
Or perhaps I should have said magnetic field, rather than flux. In any
case, the point I was trying to make is that the conductors within this
relatively small space have current induced in them only there,
** Your proof of this absurd claim is where ?
and it is a much smaller space than that of an equivalent size EI core.
** The usable copper window area is LARGER with GOSS strip toroidals than
with similar E-I cores.
My god - windings surround the ENTIRE core instead of just the middle
stump or part of it !!
( Cricket allusion will mystify all Yanks ..... )
** Gotta bend down a long way to even SEE a Lilliputian like you.
........ Phil
John Larkin
Cricket has been explained to me many times. It still makes no sense.
John
Tony Williams
stated that the location where a conductor will be most
the hole. Or perhaps I should have said magnetic field, rather
than flux.
[snip]
The imagery I have is that a straight piece of wire
carrying a current has the magnetic field arranged
as concentric rings around it. If a toroidal magnetic
core is slipped over that wire then the 'rings' get
naturally concentrated in the higher permeability core.
I've done experiments with bar-turns and toroids.
The interesting thing is that the current ratio is
not particularly affected (<0.1% anyway) by the bar
not being central, tilted, or even not round.
Paul E. Schoen
than flux.
[snip]
That is a good description of a toroid being used as a current transformer,
where a high current flows through a large conductor (or several turns of a
smaller conductor) and the smaller secondary current is used for
measurement. I recently tested a PCB mounted toroid with 1000:1 ratio, with
a load of 10 ohms, and it was quite linear from about 1 ampere to several
hundred.
For the test sets we build, we use a Rogowski coil for current measurement.
It is built using 8 air-core inductors positioned across the top and bottom
of a 6" x 1/2" bus bar. The axis of each inductor is perpendicular to
current flow. The output is a voltage which is proportional to dV/dT of
current, so an RC integrator is used. The coils read the magnetic field,
and can be affected by external fields and the presence of magnetic
material nearby (like steel brackets and bolts), but once solidly mounted,
the output is very linear and accurate over a range of about 50 amps to
50,000 amps or more.
The point I was trying to make is that only the very small portion of the
conductor through the hole of the toroid is affected by its magnetic field.
The conductors outside this small space serve merely to complete the
circuit. There is no appreciable difference if the conductors are wrapped
tightly around the toroid, or are routed far away from the outer surface.
Of course, tighter wraps use less wire and there is less resistive loss.
Paul
F
Fred Bartoli
Suggestions ?
Bifilar winding isn't possible, unless you want a 1:1 xformer, or a
total mess of series/parallel windings.
Eeyore
Why need it be a mess ?
Graham
Spehro Pefhany
Really, you are better off not knowing.
John
I'm always suspicious of endeavors that require learning a new lexicon
or require new clothes.
Best regards,
Spehro Pefhany
F
Fred Bartoli
Suppose you want a 24V xformer (a 1:10 ratio). You'll need ten winding
sections, each primary part in series, each secondary part in parallel.
I qualify this as a mess, since this level of complication isn't needed
at all for the purpose.
Robert Baer
than flux.
[snip]
As long as the cross-sectional area of the wire used (not the shape
as you correctly mentin) is the same, this is correct.
Where one can see slight modifictions of this, is when a substantial
percentage of the wire cross-section is rather close to the higher
permeability core.
Robert Baer
Bifilar windings for N:M ratios have beendone for at least 30 years;
even using coax cable!
