Winding own air core inductor
Y
yeshu26
I have my own winding machine and lot of motor wire.
Problem: There was a DOS based program available on net which
calculates the no of turns of wires required to be winderd over a core
of both round as well as RECTANGULAR.
I am looking for that program or " mathematical formula" to calculate
wire turns for RECTANGULAR CORE ( bobbin) ONLY, means the core which
is used in E I type X formers
Plz help me with formula or program
Rgds
Himanshu
[email protected]
Phil Allison
"yeshu26"
** This calculator should get you close if you modify the diameter figures
give the same area as your rectangular bobbin.
http://www.pronine.ca/multind.htm
......... Phil
Greg Neill
You might be able to pull the desired fromulae from the
source code you can find here:
http://www.moshier.net/coildoc.html
