winding your own toroidal transformer
gav
hello,
I've just finished a module of Transformer theory in trade school and was
hoping to try some of it out.
I plan on experimenting with winding my own toroidal power transformer.
I require a 1:2 step up at 20V 150hz supply aiming at 150-300VA or so.
I have found a general ballpark equation to calculate primary turns for an
EI type transformer which goes like this:
is N = (E · 10^8)/ (4.44·f·A·B),
N= number of pri turns
E= supply voltage
f= frequency
A= Cross sectional area of core (I think in square inches)
B=max flux lines = rough figure of 60,000
Using a toroidal core with a CSA of 1sq" it gives me 50 turns for the
primary.
Is this equaiton correct?
Is the value of B ok for say a Mains 300VA toroidal core off the shelf?
If anyone can help me answer these two questions, or point me somewhere that
can I would be very greatfull.
Thankyou
gavin.
DarkMatter
Thanks, plenty of usefull links there.
gavin.
The core material selected should be on par with the intended
operational parameters of the transformer in use.
Powder may not be the optimal choice for the application in mind.
Be sure to research your desired application, and select the core
material which will operate best for you in that application.
