Window Car circuit
eplanet
Mar 5, 2007
88
hi friends
can you help me how can i make window car circuit for more speed?
thanks
audioguru2
Apr 6, 2004
12,022
Are you talking about a power window that is already on a car?
Then the cost of all of its parts and wiring are designed for its slow speed. If you want more speed then you need to apply more power to a bigger motor. The bigger motor will need different and stronger gears. The fuse and wiring will need to be bigger. The control or switch will need to be stronger.
eplanet
Mar 5, 2007
88
hi
no my friend i want to make circuit for amplifier for better driving motor.
audioguru2
Apr 6, 2004
12,022
You don't make an amplifier to drive a DC electric motor. You simply feed more voltage to it. But it is difficult to make a voltage boosting circuit because then the current would also be increased. Then the motor, its fuse and its wiring will burn out. The gears will quickly wear out.
