Wiring consistency check
  • Thread starter Rikard Bosnjakovic
  • Start date
Rikard Bosnjakovic
I got a pcb-layout from a magazine, but since I've only got veroboards at
home I had to relayout it to fit a veroboard.
I've now completed the circuit and construction, but obviously there's an
error somewhere that I cannot find. I've double double checked my layout
but still cannot find it.
The original, flawless, pcb-layout from the magazine can be found here:
http://bos.hack.org/tmp/vero_pcb/pcb.jpg
And my veroboard-version for the same layout can be found here:
http://bos.hack.org/tmp/vero_pcb/Veroboard.pdf
I would be very grateful if there is anyone that's got some spare time
(around 5 minutes) to "proofread" my layout and see if there are any errors.
Thank you.
John Popelish
at home I had to relayout it to fit a veroboard.
an error somewhere that I cannot find. I've double double checked my
layout but still cannot find it.
errors.
Thank you.
I can see no errors in your layout. I would be looking for sneak
paths under C2, or a solder bridge where a hot line runs between two
pins of the connector row. Are the chip, bridge and diode oriented
correctly?
Rikard Bosnjakovic
John said:
I can see no errors in your layout. I would be looking for sneak paths
under C2, or a solder bridge where a hot line runs between two pins of
the connector row. Are the chip, bridge and diode oriented correctly?
Thank you for your reply.
I've now checked, thrice, the places you suggested without being able to
find any solder bridge or what so ever. Also, the IC, bridge and diode are
using correct orientation.
The board was residing in a box for a fresh project I build straight to
the number from the magazine. It doesn't do as supposed, to I used my DMM
to measure around on the board. The magazine tells me that the Vref on the
723 should be around 7 volts. When the board is in the board, Vref is
around 28 volts, and that's the reason I plugged it out and tested it
outside the box using only the mains-wires.
The weird thing, is that when the board is outside the box, Vref is 7
volts as it should. I take this that it means the board is okay, no solder
bridges, but the other components (connected to the board via the
connector pins) could possibly be erronious, so I guess I'll have to
connect one cable at a time to find the error source.
K
Ken Taylor
correctly?
And have you cut the tracks under IC1?
Cheers.
Ken
Rikard Bosnjakovic
The wiring on the veroboard are obviously correct so I can remove it as an
error source.
There is however one thing that I find tricky for the wiring in the case.
Have a look at this image (schematic from the magazine):
http://bos.hack.org/tmp/vero_pcb/fig1.jpg
And this case wiring schematic (also from the mag):
http://bos.hack.org/tmp/vero_pcb/fig2.jpg
P2 is supposed to change the output voltage over the pole terminals (+ and
- just under P2). The schematic is for a lab power supply and is rated to
supply between 3 volts and 25 volts, but what happens when I turn P2 is
that the voltage does not change at all except for a few millivolts.
Using my DMM for the pole screws (+ and -), it reads 3.350 V. If I turn P2
to its extents, the voltage goes from 3.350 to 3.380, and that's it.
What I'm unsure is about the consistency between fig1.jpg and fig2.jpg. In
fig1.jpg, P2 should be in series with the amp-meter, but in fig2.jpg, it
isn't (I think).
Other people I've talked to that have built this supply have had no
problems, so there is probably nothing wrong in the schematic, but I
cannot understand what's wrong. All the wiring (both for the veroboard and
for the case) are entirely to the number according to the schematics in
the magazine, but still it won't work.
In the magazine, there's a table of "testpoints" for measuring with the
DMM. Pins 6 and 5 on the 723, for example, should be around 7 and 3.5
volts respectively, and that's what I can read on my multimeter. The
voltage over the base and collector on T1 are also correct, as well as
every other testpoint in the table.
Could anyone shed some light on me for this problem? Are there for example
any obvious tests I can do to try to find the error source?
John Popelish
an error source.
case. Have a look at this image (schematic from the magazine):
and - just under P2). The schematic is for a lab power supply and is
rated to supply between 3 volts and 25 volts, but what happens when I
turn P2 is that the voltage does not change at all except for a few
millivolts.
P2 to its extents, the voltage goes from 3.350 to 3.380, and that's it.
In fig1.jpg, P2 should be in series with the amp-meter, but in fig2.jpg,
it isn't (I think).
and for the case) are entirely to the number according to the schematics
in the magazine, but still it won't work.
example any obvious tests I can do to try to find the error source?
P2, R5 and R6 form a voltage divider that must reduce the desired
output voltage to about 3 volts to be compared to the divided down 7.5
volt reference voltage. You don't provide the resistance values for
Either divider, so I can't check if they are right.
You may have P2 and R6 interchanged.
I would have preferred a different arrangement for the divider that
used the wiper as the tap that connects to IN-. That wouldn't pass as
much current through the wiper contact for a longer life, and I think,
better range.
Rikard Bosnjakovic
John said:
P2, R5 and R6 form a voltage divider that must reduce the desired output
voltage to about 3 volts to be compared to the divided down 7.5 volt
reference voltage. You don't provide the resistance values for Either
I would have preferred a different arrangement for the divider that used
the wiper as the tap that connects to IN-. That wouldn't pass as much
current through the wiper contact for a longer life, and I think, better
range.
I'm sorry, I just now realized that I should have written the values since
they are hard to read in the pdf in the OP.
R1 - 2.2k
R2 - 1.8k
R3 - 1.5k
R4 - 1k trimmer
R5 - 330
R6 - 1k trimmer
P1 - 1k lin pot
P2 - 4.7k lin pot
P1 and P2 are the ones on the case, R1-R6 are all on the board.
John Popelish
since they are hard to read in the pdf in the OP.
R1 - 2.2k
R2 - 1.8k
R3 - 1.5k
R4 - 1k trimmer
R5 - 330
R6 - 1k trimmer
P1 - 1k lin pot
P2 - 4.7k lin pot
That means that the reference voltage is 7.5*R2/(R1+R2) or about 3.375
volts.
So with R6 at maximum resistance (1k), The range for the output should
be between 3.375 minimum to 3.375*(P2+R5+R6)/(R5+R6) = 15.3 volts.
With R6 set to zero, changes to 3.375 to 3.375*(P2+R5)/R5=51.4volts,
which would allow only a small part of the rotation of P2 before the
output saturates high.
So no setting explains the low output voltage. I would ohm out the
resistance from IN- to the negative rail, to make sure something is
not open in the R5 R6 pair.
Rikard Bosnjakovic
resistance from IN- to the negative rail, to make sure something is not
I have now followed your steps and couldn't find any problems.
During the ohming, I did however check the copper tracks once more just in
case I had cut the wrong tracks or similiar. And guess what, I found a
microscopic size of solder bridging between two tracks. Removing it with a
small screwdriver helped, because now the power supply works!
Thank you John for your time and valuable pieces of information. Without
your posts I would have assumed, wrongly, that the copper strips and the
board itself was no source of an error, and would have never looked there.
Your tip about checking R5/R6 made me find the solder bridge.
John Popelish
in case I had cut the wrong tracks or similiar. And guess what, I found
a microscopic size of solder bridging between two tracks. Removing it
with a small screwdriver helped, because now the power supply works!
there. Your tip about checking R5/R6 made me find the solder bridge.
Excellent. Congratulations.
