jan
- Jan 1, 1970
- 0
Hi All,
You've helped me out before and am hoping you can do it again.
I bought three battery operated light fixtures that you use in tight
places with no electricity [like a small closet]. Each takes four
batteries, so 1.5volts in series=6 v DC.
They work great and I wanted to use all three under a cabinet and,
instead of batteries, I would use a transformer. I found an 8volt
transformer rated at 325ma and wired the lights in parallel. With one
light on, all is fine. Two or three lights on and they get dimmer and
dimmer. Finally, two of the bulbs burned out, one after another.
Should I get different bulbs [screw base], a different xformer or need
to wire them differently??
Thanks in advance.
Jan
Thanks in advance.
Jan
