wwvb receiver chip needed
Albert
I need a Temic U4224B chip, which is used for reception of DCF and
WWVB time signals at vlf.
Are these available without going to Europe?
Joerg
Hello Albert,
I am not sure you can get them at all. It might have been obsoleted by now.
Regards, Joerg
Joerg
Hello Mark,
In any case, Temic was bought out by Atmel.
I believe Atmel called this chip T4224 but when looking for it on their
web site it ain't there.
Regards, Joerg
Tim Shoppa
The "usual" way of getting a WWVB receiver chip is to buy a cheap WWVB
clock and rip out the chip and antenna. Some have external
chips/antenna connected via cable already.
A web page showing how to do this with a commonly available Sony WWVB
clock is at:
http://www.leapsecond.com/pages/sony-wwvb/
Tim.
Joerg
Hello Tim,
Agree. Many like the Sony even contain two crystals. These alone can
cost more than a whole clock.
But if it's a matter of pride you can build your own even without any
special chips. When I was a kid I built a receiver for DCF in Europe. No
crystals, only a few transistors and 741 opamps. It worked great, except
that I didn't have a PC or anything to decode the signal with. It was
just the detected pulses but these came through nice and clear. With
today's opamps you wouldn't even need any transistors to do it. A decent
quad can be had for 50c while I paid a whopping $3 for a single
re-labeled 741 of rather dubious quality level.
Regards, Joerg
Albert
Thanks for this info. Unfortunately, Atmel doesn't make the T4334 now.
But, while searching the site for keywords, I found the ATA5283 and
ATA5282 125 khz receiver chips that draw less than 4 microamps while
listening. I don't think there is anything inside the chip that limits
the frequency of operation though, these should operate at much lower
frequencies if an appropriate tuned circuit is attached.
So, I will look at these chips in detail later.
I was attracted to the Temic wwvb/dcf77 receiver chips because they
draw 30 microamps...so, a receiver that draws 4 microamps is indeed
low power and is very promising.
Regards,
Joerg
Hello Albert,
AFAIK many "atomic clocks" listen to WWVB briefly and then turn off the
receiver again. With a very low on/off duty cycle the power consumption
of the receiver wouldn't matter so much.
Regards, Joerg
Tim Shoppa
two crystals. These alone can cost more
than a whole clock.
Of the longwave radio frequencies used for time standards, 40kHz (JJY,
Japan), 77.5kHz (DCF, Germany) and 60 kHz (WWVB and MSF) crystals are
off-the-shelf items in the Digikey catalog at less than a dollar each.
I'm guessing their easy availability is because they are commonly used
in real receivers.
I've always noted with some curiosity that 77.503kHz, 60.002kHz, and
60.005kHz are off-the-shelf crystals too... used in a direct conversion
receiver for DCF/WWV to 3Hz, 2Hz, and 5Hz carrier-detect frequencies
maybe?
Tim.
Albert
I just noticed the availability of these crystals as I was thinking
about using a crystal in the front end to protect the receiver from
adjacent frequency qrm. Not sure if this can be done unless one has a
chip specially designed to take crystals (such as the Temic U4224B).
Regarding the off frequency crystals.... It might be possible that
these are rejects that didn't quite make the 60.000 kilohertx spec?
Joel Kolstad
Really...! Hmm... perhaps time to re-visit the "WWVB receiver using op-amps
and a small microcontroller" ida? One of the regular contributors to
Circuit Cellar Ink tried it a while back (4 years?), but wasn't successful.
A successful project would be worth a write-up in some hobbyist magazine (of
what's left... Nuts & Volts seems to be about it in the US...)
Anyone know which time service folks in Oz or the Kiwis use?
---Joel Kolstad
Michael A. Terrell
---Joel Kolstad
Take a look at Jim Thompson's early design. He's an IC designer who
hangs out on the sci.electronics.* newsgroups.
http://www.analog-innovations.com/SED/WWVB-Schematic+Data.pdf
Joel Kolstad
Yes, I've seen Jim's design before; it's quite impressive for 1974! For a
contemporary design, the idea is that you could get by with far fewer parts
(if not fewer transistors -- they're just buried in the ICs!).
---Joel
Jim Thompson
---Joel
Particularly considering it was done BC (Before CAD :)
Maybe I should try it again, using off-the-shelf components ??
...Jim Thompson
Michael A. Terrell
...Jim Thompson
A "Before and after"?
Joerg
Hello Jim,
To be fair you'd have to do it with components that were available at
reasonable prices in that era. My 2nd DCF receiver was built with
several AF126 germanium transistors. On the first one I cheated by using
opamps and somehow that didn't feel right back then.
Except for the fact that one receiver drove a Nixie display I never
built one with tubes. Now wouldn't that be something?
Regards, Joerg
Joerg
Hello Tim,
in real receivers.
Yes, but if these crystals are the only thing you'd have to buy right
now that would easily become $10 with S&H. Or about half of what an
atomic clock is at the discounters and there the price includes a huge
display along with the receiver parts.
maybe?
Strange. Maybe another resonance mode?
Regards, Joerg
Michael A. Terrell
Regards, Joerg
Maybe use them with the 60.000 KHz crystals to build a very narrow
crystal filter?
Joerg
Hello Michael,
crystal filter?
Maybe but most WWVB receivers are more crude. They aren't concerned
about shape factors and stuff, all they want is enough selectivity to
make sure the things sync at night even if in California or Arizona. So
there is usally one crystal as a filter, or two in series for the better
ones.
Regards, Joerg
Rich Grise
Hello Jim,
reasonable prices in that era. My 2nd DCF receiver was built with several
AF126 germanium transistors. On the first one I cheated by using opamps
Except for the fact that one receiver drove a Nixie display I never built
Yabbut, it'd be a little cumbersome for a wall clock. ;-)
Cheers!
Rich
Similar threads
