xerox 8850/510 power supply defect
aakdag
Mar 13, 2021
3
There is a Xerox 8850/510 brand printer. LL-7F error exists. I detected deformation in bridge diode legs on AC Module. I ran it after cleaning it thoroughly, the fault still continues. But this device was repaired by someone else before me. LM741 is installed instead of LM7372MR (U10 coded) OPAMP. I can not find LM7372MR in Turkey. I will order from abroad. Could the cause of the LL-7F error be LM741?
I will be grateful to you if you could help me about this problem.
Best regards.
Abidin AKDAG
Konya/Turkey
aakdag
Mar 13, 2021
3
You can NOT replace the LM7372 with a LM741.
The LM7372 is a high power, high speed, dual opamp.
The LM741 is a single, slow speed opamp.
https://www.digikey.com/en/products/detail/texas-instruments/LM7372MR/3701242
Bertus
Hello. Thank you so much Bertus,
I found the original OPAMP (LM7372MR). But the error still continues. Why could that be?
Also, I would be very happy if you share with me what the causes of LL-41, LL-45 and LL-81 fault codes are and their solutions.
