xilinx virtex2 ISP using hc12
blisca
Hello
i started last year to work(play?) with a 16bit 9s12 microcontroller,having
some surplus scraped xc2v2000 fpga's and a little experience in vhdl i
would like to use these fpga but i need some external memory for storing
permanently the configuration data.
Due to impossibility of realizing a PCB to mount a flash and the lot of
connections,i think if it is possible to use the 9s12 to program the fpga.I
would like to use it because having a good programmer with in -circuit
debugger i could check if the system is working in correct manner during
development phase.
Any ideas?
Thank you.
Diego
Milano
Italy
John Larkin
Hello
development phase.
Any ideas?
Thank you.
Diego
Milano
Italy
Sure. We always program our FPGAs from a uP, since all of our products
have a uP anyhow.
You'll need some way to merge the Xilinx bitstream data into your uP
program image, then you'll need to write a simple routine to reset the
fpga, un-reset it (PROGB pin), and then bit-bang the config data into
it, slave serial mode, using CCLK and DIN pins. It's fairly simple.
I have a PowerBasic program that builds a uP rom inage from an S28
program file and a .RBT config file, and a bit-banger in 68K assembly,
available as examples if nothing else.
Be sure to terminate CCLK at the fpga, as they are very sensitive to
ringing, and bit-bang an extra 32 bits of anything, for luck.
John
PeteS
have a uP anyhow.
John
See XAPP800 (registration required) at Xilinx. This uses a CoolRunner
to bitbang a FPGA using a SPI flash for storage, but the bit bang VHDL
is straightforward and could easily be ported to your architecture and
language of choice.
Cheers
PeteS
blisca
thank you to you both for the good support and hints!
