K
K. Donovan
- Jan 1, 1970
- 0
This thing is driving me nuts. I have a TA2009 audio amp module. I
want it to drive a PA type step-up transformer for voltage gain. IOW
around 200V out. The signal is a 60Hz sinewave. The secondary is to be
connected across a negligible load resistance, eg. wide area coil of
few turns. But when I connect the latter, it kills the signal both
sides of the xfmr.
Is there a right way to drive this coil via a xfmr or am I dreaming?
The module only does around 10W. Is this the problem? But I have tried
adding 8 ohm resistors all over the place with no result.
Ken Donovan
sides of the xfmr.
Ken Donovan
