-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I'd like to make a box which accepts 2 mains inputs and outputs
mains if either one of the inputs is on but not if both are on. Any
ideas?
Failing this, how would I achieve the same effect with 2 low voltage
inputs?
For low-voltage inputs to a low-voltage output, just buy a (VERY
cheap) XOR-gate IC, such as the 74135.
To use mains-voltage instead of ~4.5 volts, although there is perhaps
a better way to do this, I personally would convert the high voltages
to low voltages, use the IC, and then turn them back into a high
voltage output.
To turn mains voltage into a digital logic 1/0 signal, use a
transformer to drop it down to probably, say, about 12V, bridge
rectifier, and a filter capacitor of some kind, followed by a ~5V
zener diode. This'll give you 0V or 5V. You'll need one for each
input.
To turn the output back into mains voltage, use an optoisolated triac.
A basic triac switching circuit is shown here:
http://computerchristmas.com/domains/computerchristmas.com/myimages/7-Schematic.jpg
although I would suggest connecting the input labeled "+5VDC" to the
output of your XOR gate, and the input labeled "to controller" to
common ground. Everything else can stay the same. The MOC-3010 is an
optoisolator; if you get a different optoisolator, you may need to
change the values of the resistors. TR1 is your triac; the diagonal
line is the gate, while the two vertical lines are the main
terminals. It'll probably only work with the main terminals connected
one or the other way around, so if it should be on but isn't, try
switching the main terminals. As the schematic shows, just put in
series with the circuit that would normally consist of the mains
supply and the load.
Chris
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
iD8DBQFAhxAhnwjA8LryK2IRAswaAJ424ys4AuQrbncK+OJ44k4GYX+94gCcCqSn
1jKMydnnrSK9rIPkH8Um6P4=
=UaPp
-----END PGP SIGNATURE-----
