Yamaha RX-V 657 comes on then goes off
jmm83
Apr 12, 2018
3
Hi
I have a Yamaha RX-V 657 that i bought from goodwill for $5
when the power button is pressed it comes on for 2 seconds and then goes off
when i tried it with a dim bulb test it came on and stayed on but the bulb was lit a little bit
so i think there is a short somewhere
when plugged into the dim bulb tester i did try the speaker outputs using the tuner and they all worked so i don't think it's any of the transistors on the amp board
when i tested the CB354 connector on the power supply the voltages were low and when i unplugged the connector and tried to power it on it came on for one second and went off but the bulb did not glow that time. so im thinking it must be something on the power supply board or maybe the transformer
jmm83
Apr 12, 2018
3
So the units working then? or are you quoting this wrongly?
it's working when it's plugged into the dim bulb tester
but when plugged straight into the power outlet it comes on for one sec. and then goes off
adir figueiredo
Apr 18, 2015
3
eta aparecendo que tem canal em curto
Translation:
It's showing that the channel is shorted
