Yamaha SPX 90, 1986 , Digital Multi Effects Processor
N
N Cook
Been looked at by one supposed repairman and returned in a sorry state.
SMPS problem initially , but now could be more than that.
I don't suppose anyone has a schematic for this kit, may not be necessary
but just in case.
Local recording studio's favoured piece of kit , with no full modern day
replacement it would seem
jakdedert
but just in case.
Millions of them made, superseded by the SPX 900. All the programs
within also contained in the much more capable REV-7.
The 90's and many other Yamaha devices of the mid-80's suffered from a
potting compound which often turns conductive with age....
jak
N
N Cook
jak
Cold checking , have found 2 things wrong with the ps so not powered up yet
No SMPS controller IC on the ps board , a TOP66 switcher driver and 3 small
transistors.
Raw + and -18V go to main board +/-15V regulators , raw 5V , ie rectifier
off the switching transformer followed by one L and one C goes straight to
the 5V TTL rail. Not even an obvious fat 5V zener across it.
No SMPS controller IC , that I can see on the main board and the 2 lines
from the main board marked PE and PC that go to the mains side of the ps via
opto isolator , I'm assuming is go / no-go for the moment.
5V regulation via the whole ps unit ?
very strange
N
N Cook
transistors.
very strange
There are 15 assorted wirewound resistors on this ps , again rather odd.
If I get it working , a ventillation hole and grill cut in the top cover
would help.
Ron(UK)
would help.
Shouldn't be needed, those things get racked up in close proximity to
other units for years without overheating, they are normally considered
extremely reliable even when running 24/7.
Although considered a 'classic' in it`s day, there are several modern
units which outperform the SPX90 at a far lower price.
If you really get stuck and it`s imperative that it gets repaired, drop
me a line, I know of a company up here in the North who will definitely
sort it out.
Ron(UK)
N
N Cook
sort it out.
Ron(UK)
Lune Valley Audio
Public Address Systems
Hire Sales Maintenance
www.lunevalleyaudio.com
It was that hand over period , 80s , when phenolic pcbs went over to
polyester.
This Yamaha has polyester main board and phenolic light brown ps pcb that
has a lot of heat dark browned/brittlised? areas. Not surprising with
assorted 15 W/W plus sm driver etc with no ventilation holes anywhere.
N
N Cook
sort it out.
Ron(UK)
Lune Valley Audio
Got it back to working to its earlier non-working condition before it was
seriously
mangled by a "repairman".
Can now see that the original problem was an 85 dec C electro that did not
like being cooked in there.
The 5V regulation, unlike the +/-15V, is on the ps itself, in discrete form,
consisting of 300mW zener,preset and TO92 transistor.
N
N Cook
Hopefully get back to this one tomorrow.
Working at 2/3 mains coltage but temp of the chopper transistor goes too
high, if I let it, and power consumption goes well above 20W.
Looks as though something has gone wrong with the mark/space contol.
It slowly increases so the "5V" line goes 2..3V and then jumps to 5V with
equal mark/space which is presumably not necessary.
I will check there is no excessive load on the +/-18V or 5V rails despite
all functions working as far as front panel display.
I've not established the function of the feed forward optocoupler from the
main processor board to mains side of the ps
N
N Cook
The second optocoupler is the other way round.
Feeding rectified but unsmoothed mains signal info to the main board.
Phase info for mains hum/noise reduction?
N
N Cook
I think I've cracked it, one of the most awkward of repair situations.
A previous er-um repairman had got there before me.
I can only assume that the previous one noticed a component populating a
pair of holes , on traces, with no corresponding overlay graphic outline or
designation and removed it as suspicious. Numerous such holes, unused for
this model, on the pcb .
I assumed, from the disturbed solder , that he'd tried something temporary
at that point but it looks as though there was originally a small C there
that slowed down the HV response to the LV error amp via opto coupler.
The optimum error V was about 5 minus 2.2V but it was racing over that up to
5V, as there was no capacitance in the error amp, so cutting off the OC and
forcing the HV oscillator to maximum power consumption and all error control
lost.
Now just a matter of finding the optimium, educated guess/suck it and see,
for that C, 100nF works but going by pin spacing must be less than that.
