Yellow Glue strikes again
Phil Allison
** I had hoped that the dreaded Yellow Glue peril had gone away - but it is
still with us.
Most of you will have seen it holding parts down to PCBs on Asian made
equipment and many of those will have seen what happens if the parts
involved get hot.
The example on my bench is the SMPS from an Alesis powered monitor ( M1
Active, Chinese made) ) which has blown up big time because of the damn
Yellow Glue used to secure a ferrite toroidal coil. All the glue used had
gone brown or back ( ie carbonised ) on this coil and arced across nearby
tracks taking out the main switching MOSFET, its drive IC and associated
transistors, high speed diodes and even the AC bridge rectifier diodes.
The toroidal coil had to be un-wound, cleaned up and re-wound. The same glue
was attacking parts elsewhere on the board too ( it corrodes copper) and had
to be laboriously scraped off.
Are the dickheads who squirt this horrible goop all over PCBs NEVER going
to wake up ??
...... Phil
Jeffrey Angus
Is that hot melt glue or something else?
Hot melt should, umm... melt, not burn.
No, this crap looks like 3M weather strip adhesive.
Sometimes it looks like it's applied sparingly, other times
it looks like it was put on with a caulking gun.
Jeff
Phil Allison
"Jeffrey Angus"
** I've always wanted to know just WFT it really is !!
At first impression, it looks like ordinary contact adhesive - but it is
quick setting and dries to a hard surface. With time and heat it become tan
coloured and brittle. Then it goes toast brown and becomes corrosive and
conductive.
If coating the pins of an op-amp, the leakage current causes DC offsets and
crackling noises.
If coating small diodes and resistors etc - it will slowly eat the leads
right off.
If coating PCB tracks with hundreds of volts between them, the conduction
heats the glue directly until there is an explosion.
IME , a local ambient temp of about 55C is enough to set it off on its
pathway to hell.
..... Phil
Jeffrey Angus
It's probably related to that crap rubber they love to use
for drive belts and such that turns to extremely sticky goo
that's next to impossible to clean off of everything it
touches.
Jeff
Phil Allison
"Jeff Liebermann"
Just answer the question.
** You are not a repair tech, or you would have seen it many times.
Always Asian made gear, from about the 1980s onwards.
TV sets, VCRs, SMPSs anything where the maker felt it was a good idea to
glue things to the PCB.
Do a Google search on this NG under " yellow glue".
...... Phil
Jeffrey Angus
"One component solvent resistant flame-retardant waterproof yellow
fixing adhesive glue for electronic components"
Odd, I read this: "Usage: Construction, Fiber & Garment, Footwear "
Jeff, but yeah, that sure looks like it.
Some of the stuff looks almost porous.
Jeff
Phil Allison
"Jeff Liebermann"
This description seems to fit:
<http://www.alibaba.com/product-gs/482344777/One_component_solvent_resistant_flame_retardant.html>
Note the photos. Is that it?
** Sure as heck looks like the vile stuff.
But the stuff has been in use for decades, firstly with Taiwanese made gear.
The specs quoted do not mention aging or the effects of temperature - so the
marketing is dishonest.
BTW:
the pics show the glue in its liquid state, when dry the surface is quite
dull.
To me, the pics are cringe worthy.
Like looking at pics of child abuse.
..... Phil
N
N_Cook
Note the photos. Is that it? I'll do some more Googling later. Gotta
seperate my customers from their money.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558
# http://802.11junk.com [email protected]
# http://www.LearnByDestroying.com AE6KS
That "Japanese" brown gloop made a comeback also, from my trepair briefs
Sherwood RD6106 tuner amp, may 2000 from front panel moulding
I though that hygroscopic brown glue stuff went out in the 70s. Used to
secure 12.288M crystal for the digital interface processor YSS912C-F , was
around its
pin and had rusted through at the epoxy bond.
N
N_Cook
If the brown hard-glue is the same as the yellow stuff. Is the progress to
destruction that it becomes hygroscopic going from yellow to brown and so
becomes conductive for CMOSSy sort of stuff but if HV around then conducts
enough to then carbonise and become ever more conductive?
Cydrome Leader
Phil Allison said:
"Jeff Liebermann"
that stuff is pure shit.
chuck
still with us.
involved get hot.
to wake up ??
..... Phil
The rumor among techs in the U.S. when this stuff first showed up was
it was originally manufactured by Sony and it was known as "Sony
glue". Don't know if there was any truth to this or not. As Phil
said, it was in widespread use, for example: Mitsubishi televisions,
Adcom preamps and tuners, Yamaha receivers, Extron products and many
others which I can't recall off the top of my head. Chuck
Trevor Wilson
**No. It is a type of contact adhesive. It is still in widespread use, for
reasons I don't understand. Some, more enlightened manufacturers, use a
silicon type glue, which has a much higher burning temperature.
Andrew Rossmann
to wake up ??
As long as it lasts through the warranty, they don't care.
Meat Plow
is still with us.
involved get hot.
had gone brown or back ( ie carbonised ) on this coil and arced across
nearby tracks taking out the main switching MOSFET, its drive IC and
associated transistors, high speed diodes and even the AC bridge
rectifier diodes.
glue was attacking parts elsewhere on the board too ( it corrodes
copper) and had to be laboriously scraped off.
going to wake up ??
..... Phil
Yup been there in the past 30 some years. Lots of Chinese VCR SMPS. I
reckon that crap is a moisture trap that eventually leads to the demise
of chokes, coils etc..
Alien
Aw, geez.
<smacks forehead>
It's not a 'moisture trap', you freaking retarded dildo muncher.
The glue gets carbonized due to excessive heat in the electrical
components, which makes the glue more conductive and more corrosive
(ie: it chemically changes the glue).
This causes havoc due to shorts (because it's conductive) and open
circuits (because it corrodes away circuit traces and component
leads).
Gawd but yer stupid.
'moisture trap'! Bwahahahaha!!!
Fixed yer .sig., stupid.
Yer welcome.
'moisture trap' <snigger>
The only 'moisture trap' is yer ass, and the only 'moisture' it
'traps' is the spooge of a thousand gay bikers, you old fat ugly
retard.
___ ___ ___ ___
/\ \ /\__\ ___ /\ \ /\__\
/::\~\:\ \ /:/ / /::\__\ /::\~\:\ \ /:/|:| |__
/:/\:\ \:\__\ /:/__/ __/:/\/__/ /:/\:\ \:\__\ /:/ |:| /\__\
\/__\:\/:/ / \:\ \ /\/:/ / \:\~\:\ \/__/ \/__|:|/:/ /
\::/ / \:\ \ \::/__/ \:\ \:\__\ |:/:/ /
/:/ / \:\ \ \:\__\ \:\ \/__/ |::/ /
/:/ / \:\__\ \/__/ \:\__\ /:/ /
\/__/ \/__/ \/__/ \/__/
WHO IS 'MEAT PLOW' from Alt.Usenet.Kooks (AUK)?
The obese, abusive, ugly, snaggle-toothed, giant-headed, stalking, gay
'bear' biker retard who likes to surf gay porn sites as 'BlancoBear'
while wearing only assless chaps:
William Malone Griffith, Jr.
(aka Milt, Meat Plow, BlancoBear, [email protected], Tripp)
308 10th Street NE
North Canton, OH 44720-2023
Some of this sick ****'s best work, and comments from others about
him:
http://groups.google.com/group/alt.buzzard.rules/msg/f630759d6303a19d
Message-ID: <[email protected]>
Meat Plow on a stalking holiday excursion, 15 to 22 Aug 2011:
http://groups.google.com/group/alt.usenet.kooks/msg/03314ab006d88a5f
Date 06 Aug 2011
Title: Guess who is going to be in West Palm Beach?
"ME! Got a couple friends who invited me down for a few days. Shit
that's only 60 miles south of Melbourne LMAO!"
Nevermind that West Palm Beach, FL is 110 miles (not 60 miles) from
Melbourne, FL.
http://groups.google.com/group/alt.usenet.kooks/msg/c1438fbeda11457f
Date 06 Aug 2011
"Got my itinerary set on Expidia. Will be at PBI on August the 15th
at 11:30 am. Got a nice 2011 Jeep Grand Cherokee reserved. I'm hoping
to make it up to Melbourne (Albatross hit my email) before the 20th
when I have to return."
http://groups.google.com/group/alt.usenet.kooks/msg/43855b424693fa60
Message-ID:
<[email protected]>
Date 17 Aug 2011
Title: MEAT-PLOW LIED AGAIN! (and gets smacked down YET AGAIN!)
"I have several videos and pictures of him riding and what I'm sure
pie the location of his tent."
http://groups.google.com/group/alt.usenet.kooks/msg/19e83b3eb6233fe2
Date 21 Aug 2011
Title: Emmy takes the day off.
"Well I leave tomorrow at around 7:am. Got some nice video and still
pix of the little shitty pants. There will be another Youtube video
soon"
Hmmm... only one and a half days 'visiting friends in West Palm Beach'
(if he was ever there to begin with), and the rest of his time in
Florida spent real-life stalking. He even extended his stay by two
days, so he could get in more stalking.
Evidence that Meat Plow is William Malone Griffith, II:
http://groups.google.com/group/alt.usenet.kooks/msg/5650f8e1e7dedefa
http://groups.google.com/group/sci.electronics.repair/msg/e52ffbb346f5b764
http://groups.google.com/group/alt.usenet.kooks/msg/a94a2a11df601e39
http://groups.google.com/group/sci.electronics.repair/msg/ef80aad2e7db945d
Meat Plow personal info:
Birthdate: Oct 3, 1955
Amateur Radio callsign N8NCX
Technician Plus
(2 meter, 6 meter)
Photo of MeatPlow in Belden Village Music store (his sister's music
store):
(Note the guitars in the background, the planet-sized head,
the rotten-Chiclet teeth, and general look of retardation)
http://www.productwiki.com/william-malone-griffith-ii/lists/
http://images.productwiki.com/upload/images/william_malone_griffith_ii_avatar_1_0-150-150.jpg
Photo of William Malone Griffith, Jr. from uffnet.com:
(Note that it's the same person as in the photo above)
http://www.uffnet.com/library/headlines/images/news1376621745xlb.jpg
He's got his father's nose and eyes:
http://www.legacy.com/guestbook/kentucky/guestbook.aspx?pid=2527782
http://mi-cache.legacy.com/usercontent/guestbook/photos/2005-09/6966764.jpg
Meat Plow email addresses:
http://web.archive.org/web/20010305113423/http://www.k1hk.org/ugb_archive3.html
"Bill N8NCX [email protected]"
wgriffit at neo.rr.com (neo = North East Ohio)
mhywattt at yahoo.com
mhywatt at yahoo.com
Meat Plow's brushes with the law:
1}
http://www.starkcountycjis.org/crim...ss_first_name=William&pass_last_name=Griffith
2}
http://www.starkcountycjis.org/civi...?case_year_no=2009-3533&litigant_txt=Griffith
Meat Plow quotes:
Meat Plow, explaining that his computer has no Master Boot Record
because he runs Mandriva 2010, not Windows:
"Wouldn't know, it's been months since I've booted a Windoze OS."
Meat Plow describes his high-powered legal team:
"You know i have a legal team who specializes in internet law. And I
won't hesitate to get them in on the action."
Meat Plow losing his connection to reality, insinuating that he's law
enforcement:
"I could be LE posing as Meat Plow. It can't be dis-proven."
Meat Plow visits a massage parlor for a Happy Ending massage.
But they refused to give him a Happy Ending his second time there.
That explains why he's gay, he's so repulsive that he can't even PAY
for HAND JOBS from women.
http://www.clreviews.com/forums/showpost.php?p=11679
"One time I got a HE, and the 2nd time I didn't. I was asked if I was
there both times and said I was. That's is why I didn't know if I said
something wrong the 2nd time which made me not get a HE."
Well, at least we know what he does with his weekends.
Oh, William, what would yer family say if they learned yer secrets?
Mother:
Catherine & Angelo Griffith
4760 Echovalley St. NW
North Canton, OH 44720-7504
330-494-5785
Daughter:
Julia M. Griffith
308 10th Street NE
Sister:
Pamela L. & Roger R. Werling
{ son Todd E. Werling (Ft. Wayne, IN) }
{ son Chris (Kennesaw, GA) }
{ son Keith (Ft. Wayne, IN) }
{ grandson Easton }
{ grandson Zakary }
{ granddaughter Camella }
7704 Bisque Court
Fort Wayne, IN 46825-3501
260-489-6086
Sister:
Cheryl J. & Jason 'Sparky' Humberto E. Rivera
{ daughter Christina }
{ daughter Rosalio (North Canton, OH) }
{ daughter Maria (North Canton, OH) }
{ son Len Gray (Ft. Worth, TX) }
5225 Echo Valley St. NW
North Canton, OH 44720-9702
Belden Village Music Store
6787 Wales Ave NW
beldenvillagemusic.com
330-497-9292
Rosalio B & Maria I Rivera
444 Wales Rd. NE
Massillon, OH 44646-5875
330-833-4291
PO Box 35093
Canton, OH 44735
Sister:
Carol L. & Ric A. Campbell
{ son Richard }
{ son Christopher (North Canton, OH) }
{ son Brandon († 30 May 1996) }
{ daughter Erin }
6794 William Tell Ave NW
North Canton, OH 44720-6546
330-497-7980
330-499-5107
PO Box 36473
Canton, OH 44735
Sister:
Christine H. & Shelton M. Vick
{ son Matthew }
3915 Harvard Ave NW
Canton, OH 44709-1538
330-493-5645
Re/Max Edge Realty
North Canton / Massillon / Canton
Realtor Christine H. Vick
6929 Portage St. NW
North Canton, OH 44720-6535
330-236-5100
888-830-6509 (fax)
330-904-0883 (cell)
www.MyOhioHomeFinder.com
[email protected]
Sister:
Angela C. & Mark Warshefski
11 SE 12th St.
Pompano Beach, FL 33060
954-785-4716
330-942-0584
Cousin:
Eddy Dailey
Bergholz Super Mart
861 Washington St.
Bergholz, OH 43908
740-768-1018
Bergholz Financial Corp.
dba SuperMart
PO Box 545
524 Garfield St.
Bergholz, OH 43908
Cousin:
Donna L. Dailey
524 5th St.
Bergholz, OH 43908
740-768-2416
Bergholz Super Mart
861 Washington St.
Bergholz, OH 43908
740-768-1018
Bergholz, OH EMT
Cousin:
Bill & Joyce Leas
{ son Billy }
243 2nd St.
Bergholz, OH 43908
Niece:
Rachel & Adam T. Livengood
{ son Lukas }
{ daughter Lauren }
6342 Palmer Dr. NW
Canton, OH 44718
330-497-7754
Izzatchoo, or yer dead daddy?
William M. Griffith
between 3rd and 4th St.
between Monroe and Lincoln Ave.
Bergholz, OH 43908
740-768-2539
What would yer landlord for 308 10th St. NE,
North Canton, OH say if they learned yer secrets?
David S. and Joan R. Shaner
2095 Waterbury Dr.
Uniontown OH 44312
330-699-4042
What would the employees at yer family's
business say if they learned yer secrets?
Ohio Kentucky Oil Corporation
aka Ohio Oil & Gas Exploration (defunct)
aka Ohio Kentucky Coal Company (defunct)
5112 Portage St. NW
Canton, OH 44720-6856
(330) 494-8810
(330) 497-7980
110 E. Lowry Lane
Lexington, KY 40503
(800) BUY 4 OIL
(800) 289-4645
(859) 223-5656
(859) 223-5946
(859) 276-0699 (fax)
(859) 276-3500
(859) 276-4080
http://www.ohiokentuckyoil.com
[email protected]
[email protected]
Oh, but wait, Ohio Oil & Gas Exploration is no longer incorporated in
Ohio:
Daddy Griffith's petrol exploration company (defunct):
http://www2.sos.state.oh.us/pls/bsqry/f?p=100:7:3376481605987832::NO:7:P7_CHARTER_NUM:384125
Nor are any of the other businesses yer daddy started. You let them
all fail:
Daddy Griffith's stables (defunct):
http://www2.sos.state.oh.us/pls/bsqry/f?p=100:7:3376481605987832::NO:7:P7_CHARTER_NUM:377966
Daddy Griffith's motel business (defunct):
http://www2.sos.state.oh.us/pls/bsqry/f?p=100:7:3376481605987832::NO:7:P7_CHARTER_NUM:377965
Daddy Griffith's drilling company (defunct):
http://www2.sos.state.oh.us/pls/bsqry/f?p=100:7:3376481605987832::NO:7:P7_CHARTER_NUM:347837
Daddy Griffith's metals business (defunct):
http://www2.sos.state.oh.us/pls/bsqry/f?p=100:7:3376481605987832::NO:7:P7_CHARTER_NUM:552193
And Ohio Kentucky Oil Corporation is on its last legs, inundated with
securities fraud lawsuits and EPA lawsuits. It's barred from
soliciting investors in Tennessee due to securities fraud, it's under
investigation in Ohio and Kentucky, it owns no oil assets or wells,
and it no longer does any of its own drilling. It'll be gone soon,
too.
And you've squandered everything Daddy Griffith earned from his
businesses, so yer now poor, adding insult to injury.
You being poor is why you issued the following. You knew you didn't
have ten thousand dollars or so to defend yerself against yet another
lawsuit:
William Malone Griffith, II's grovelfest of an apology for being a
fucktard stauker:
http://groups.google.com/group/alt.usenet.kooks/browse_thread/thread/8d753c94bd612f4e
http://www.freak-search.com/en/thread/3859383/meat_plow_exposed
http://groups.google.com/group/alt.usenet.kooks/msg/c9fccf0d1ab26ace
Title: Apology to Charles Novins
The witnesses to this abject, groveling apology:
Angela Griffith = Angela C. Griffith-Warshefski, William Malone
Griffith, Jr.'s sister
Catherine Griffith = William Malone Griffith, Jr.'s mother
Julia M. Griffith = William Malone Griffith, Jr.'s daughter
Cheri Griffith = Cheryl J. Griffith-Rivera, William Malone Griffith,
Jr.'s sister
Justin M. Griffith = ?
Kristy Griffith = Christine H. Griffith-Vick, William Malone Griffith,
Jr.'s sister
Questions yet to be answered:
Who is Justin M. Griffith?
Angela C. Griffith-Warshefski came all the way from Pompano Beach,
Florida to witness and sign MeatPlow's apology letter?
Or did William Malone Griffith, Jr. forge the witness signatures,
which would indicate some level of insincerity in the apology?
If William Malone Griffith, Jr. did indeed forge the witness
signatures, is his family cognizant of him using them in this way?
Who is Deborah Ann Griffith?
Who is Sherri Renee Christie, William D. Christie (age 54) and Lillie
L. Christie, and how are they associated with William Malone Griffith,
II?
1345 Bison St. NW
Massillon, OH 44647
330-833-5313 (Sherri)
330-837-4967 (William)
2524 Meadows Ave NW
Apt. 4
Massillon, OH 44647
PO Box 36221
Canton, OH 44735
It's time for a digital enema to flush this turd named William Malone
Griffith, II out of the system.
The exit is -.
thataway
Phil Allison
"Alien"
leads).
** Correct.
The worst problems are always with gear that runs 24/7.
No chance for moisture ingress there.
..... Phil
N
N_Cook
Another miscreant is some formulation of conformal coating that over 20 or
30 years breaks down to an oil, either itself corrosive or hygroscopic and
then corrosive
Meat Plow
"Alien"
** Correct.
Just because gear runs 24/7 does not exempt the possibility of moisture
intrusion. Ask a marine electronics tech and get back to me. Bar that,
operating electronics in high humidity 24/7 holds no guarantee that it is
not exempt to moisture. Read the fucking manual for the operating
extremes if you doubt me.
Phil Allison
"Meat Plow = **** Head "
intrusion.
** It does when the yellow glue areas are all permanently hot.
Try following the thread - fuckwit.
..... Phil
