W
Watson A.Name - 'Watt Sun'
- Jan 1, 1970
- 0
Hokay, some measurements of the circuit posted here a few days ago.
The circuit is LED_regulator2.png.
Input V = 1.50VDC.
Input I = 16.3 mA.
Assumed LED V = 3.5V (This is the approx forward voltage of the LED.
I tried measuring the V but it measures a few tenths of a volta with a
DMM, so I know that most of the current thru the LED is during the
flyback pulse across it.
Measured LED current = 4.4 mA. (This is across a 1 ohm resistor
placed between the junction of the LED and 4.6 uf cap and the rest of
the circuit.
LED power = 3.5V * .0044 mA = 15.4 mW.
Efficiency = 14 mW / 24.5 mW = 62%
and so, despite the use of the LED itself as the rectifier, the
efficiency of the circuit is not very good at all. This is the
efficiency that I got from many of the circuits I built using the
circuit on the left of the pic at
http://www.belza.cz/ledlight/ledm.htm.
For an inductor for this circuit I used a 100 uH inductor that I
bought from Mouser. Then I used a 100 uH toroidal inductor I made
from a RFI suppression sleeve that I took off a keyboard or mouse
cord. I've found that the inductor should have low DC resistance.
I put a 100 uH toroidal inductor across the 560 uH, and the LED
current increased by less than a mA, but the total current increased
to 22 mA. The increase in brightness was barely perceptible, but at
reduced efficiency. So this is apparently not the way to go.
I'll have more experiment results later.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Input V = 1.50VDC.
Input I = 16.3 mA.
the circuit.
