Zero ohm resistor ?
mowhoong
yesterday I brough a x'mas three kit set for soldering, But the circuit use
four nos. of zero ohm resistor.Can any person know what is that mean, can we
use jumper wire to substitute ? Thank you.
peterken
2 possibilities...
- it's just a jumper wire to ease crossing on the pcb
- it's used as "fusible resistor" for protection of the circuit
Clarence
peterken said:
2 possibilities...
TOP POST REPAIRED! Ecch!
Yes. However "Zero Ohm Resistors" are commonly used to select options or in
some cases (since the actual resistance is about.01 ohms) as a current sense
resistor.
Never used as a "fusible resistor" since it will carry much more current than
any other element in the circuit! Also, not made to open readily! A diode is
a better fusible component.
petrus bitbyter
use
we
Zero Ohms resistors are used for wire bridges on single sided printed
circuit boards. They are used instead of pieces of wire as they can be
handled easier, especially by placing machines. Ever saw a board with tens
of them. Obviously designed by a lazy or incompetent pcb designer. As these
resistors are made to replace jumper wires, you can replace them by the
jumper wires they replace :)
petrus bitbyter
rein wiehler
peterken said:
2 possibilities...
sounds like a jumper to accommadate single sided pbc layout
CFoley1064
Subject: Re: Zero ohm resistor ?
Date: 11/19/2004 2:38 PM Central Standard Time
Message-id: <[email protected]>
A diode is
Sorry, not quite. The old "crystal" diodes would fail open pretty reliably,
but modern diodes frequently fail shorted, too.
Fusible resistors have their place. The spec tells their current rating.
Also, several manufacturers make small axial lead fuses which have the same
form factor as a 1/4W resistor.
Good luck
Chris
Clarence
Good luck
Chris
Then YOU should use the fuse!
Rich Grise
They are zero-ohm "jumper resistors", IOW, the zero-ohm "resistor" _is_
the jumper wire.
http://www.irctt.com/pdf_files/ZEROHM.pdf
And as has been said by others, they are easier for the stuffing machine
to handle than wires with spaghetti.
Cheers!
Rich
Rich Grise
I've worked for a battery charger manufacturer, and they used "fuse wire"
which was rated in amps, like 20, 30, 40 and so on. When they blow, it's a
mess since molten metal drips all over everything. It handled like fat
solder. A fusible link was generally a couple of inches, with a lug at
each end (crimped _and_ solder-dipped =:-O ), bolted right onto the diode
stud.
A fusible resistor is, as he's said, a resistor that will open like a fuse.
If what you're looking for is just fusing, then probably a fuse would be
your best bet.
I'm only a tech[0], but I would _never_ use _any_ component in a way where
the things that are supposed to cause it to blow up are a part of the
normal operation of the circuit. In other words, _don't_ use a diode where
you're supposed to use a fuse!
Good Luck!
Rich
[0] with approx. 45 years' experience, only ~10 of which were as a larva. ;-)
