DC Motor Driver using L293D
DC_motor_driver_photo_4_th
This project is a DC motor driver, suitable for motors of low or medium power. Allows controlling up to 6 motors or 3 motors if you want to control the rotation of the motors.
Description
The controller is build around the IC L293D that can provide 600mA per channel, and a H-Bridge designed with transistors NPN and PNP transistors, than can provide 1.15A per channel.
The controller has the following connections:
  • INPUTS (A, B, C, D ,E, F). These are receiving the analog or digital signals that can be sent for example, from a microcontroller.
  • ENABLE (E1-2, E3-4). These activate the inputs from the L293D. The supply voltage can’t be higher than 7V.
  • OUTPUTS (+M1, -M1, +M2, -M2, +M3, -M3). Here is where the motors should be connected.
  • +9-12V. Here’s where is connected a supply voltage that will give power to the motors. This input, gives voltage in the L293D and the H-Bridge, the supplied voltage have to be 36V max, but for the H-Bridge it’s recommendable to use 24V max. (In case you want to use only the L293D, you can remove the jumper).
  • +5V. This input receive the logic supply voltage for the L293D. You can connect a supply voltage higher than 5V because this input it’s connected to a voltage regulator (LM7805), but you not must to exceed 30V.
DC_motor_driver_photo_6
Schematic
Schematic
Connections
Example_Connection
PCB
3D_pcb
3D PCB
DC_motor_driver_photo_1
DC_motor_driver_photo_2
DC_motor_driver_photo_33D PCB Render
photo_1
photo_2
photo_3
photo_4
14 Comments
junaid
I have a circuit of your products which has a L293D, 2 resistors, 2 led’s,2 motor slots(motor1 & motor2), 3 pins {GNG},and some more pins will please tell me what is it ?and how to use it ? Thank you
Praveen
How to give control signal to L293D? can it be given through Arduino ? If so how to program it? Kindly give a resource.
Luqman Hakim Noresham
Hye, I would like to ask can the driver control 3 motors simultaneously? since there are 3 motor output shown in the diagram.
leandro
Hello, can it use CNC driver? https://www.youtube.com/watch?v=OzF3m-P1nFM
Ben
Can this control 4 motors?
Ahmad
Hello, i must say that’s a quite great board. If you still up answers to questions, i got some because i’m looking to redraw the schematic and try to add another l293d to control 4 motors (2 motors both on each IC chips), but i’m not that bright to understand how to rewire the resistor and the capacitor. Do you need to draw another one of each, or just try to wire it?
I just finished my board! If there is any way i can share the picture with you i would be happy to do so?
RELATED PROJECTS
TOP PCB Companies
