495 -
Posts posted by gogo2520
I use Eagle
They have a free demo that will let you draw a schematic and then convert it to a pcb but you have to place the parts on the board befor you use auto router. i didn't like it at first until I got used to. Works good and its free, you can even print with it. plus other things you might need to do.
gogo -
Check this out
http://www.web-tronics.com/bagolred5mm1.html
100 leds for $1.50 thats $15 a thousand.
gogo -
Hi logan
You mean something like this
http://www.web-tronics.com/esdsacpucore.html
I don't have one of these yet. But it would be nice to have.
You don't want the cold soldering Tool I got, I broke one tip trying to make it work and the other on is the big one. It take 4 aa battires to get it to work and you might get 5 good solder joints out of it befor you have change batteries.
gogo -
I have one and ya it looks pretty. I don't use it because it sucks up battires fast. and you really got to fanagel around with it to get it to solder. Its like a test to see if its going to work this time or not. Like I said I got one, its on my bench or shelf someware and it sure looks pretty. Good thing I got a weller too ;D
have fun
gogo -
Ok
I don't understand the language but from the schem I think if you had two voltage regulators even if they had the same voltage out put one would go to the led readout and the the other would go to the sensor, should work. The Positive rails would need to have small diodes to prevent feed back.
gogo -
Hi
I have been following this read and its interesting but the thing I don't understand is what is the best way to go about makeing the power supply?
There has been a lot of post but still it seems like the whole project is still unsetedly. Mixo gave up on it for good reasons I think but its still going on.
Audioguru and Mp, please make it work and then talk about or go with mixo.
Thank you
gogo -
How cheap and how many. also do you have a data sheet?
gogo -
Check this out
http://www.martindalecenter.com/Calculators.html
Have fun
gogo -
Hello $@$
Do you know how to program a microcontroller? I think there are a couple of web sites you should look at, These will give you a good start.
http://tutor.al-williams.com/pic-intro.html
http://www.winpicprog.co.uk/pic_tutorial.htm
and
http://www.mikroelektronika.co.yu/english/product/books/PICbook/picbook.htm
That last one also has a good online electronics begginers book.
have fun gogo -
Check this out
http://www.mpja.com/category/LEDs/LEDs.asp
have fun gogo -
Hi Ante
found this on a search last week
http://www.imagesco.com/articles/picstepper/01.html
Not sure what language the code is but I an going to rewrite it in asm.
have fun gogo -
So do I
Thats a 8051 board wicth isn't bad but it will take a lot of time to program. If your just looking to controll one machine there is a product out there called mini brick. What that is a small selfprogramming controller that will operate relays at different time periods. We use them all the time were I work at. I work at a Amusement Park. Life is fun. Anyways we use the minibricks to controll lights, air cyclinders, sound machines, and whatever needs to be controlled.
have fun gogo -
Thank You Audioguru
I'll give it a try
have fun gogo -
Someone was looking for large sheets of this stuff a while back and I ran across this
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=977-8134&SEARCH=9778134&ID=&MPN=169P84WEC1&DESC=169P84WEC1
Have fun gogo -
hi Guys!
well! i want to ask you people two very important questions:
1) Why electrical energy is prefered over other forms of energies?
What eles would you use? Its clean, easy to control, and easy to produce. I wish someone would make a afrodable electric car, that would cut polution more then hafe.
I was around when coal was the main source of heat, I also used oil heat neither one is clean. Gas is better but still polutes. I don't know what eles is there.
gogo -
Hello
GMRS (General Mobile Radio Service) is a UHF personal radio service allocated 8 frequency pairs and 7 non-paired frequencies in the 462 MHz and 467MHz bands.
Family Radio Service (FRS)?
FRS is a private, two-way, very short-distance voice communications service for facilitating family and group activities.
I copy this off a web search
have fun gogo -
Here is a site that might help you
http://pminmo.com/
Its has some good and well tested projects.
gogo -
Hi mumcs
your going to love this site
http://www.geocities.com/CapeCanaveral/Lab/9643/TraceWidth.htm
It should help you out.
have fun gogo -
I guess I don't unstand the question. One point would be the same no matter what because you would have nothing to compare it to. Unless you had a second Point to compare it to there is no differance.
And hopefully that ducks right wing is the same or the duck wouldn't be able to fly stright.
have fun
gogo -
There about the same except the expensive one looks more pro but the cheaper one has more advanteges. 1st it comes with jumpers 2nd you can clip on more more boards and make it bigger. I would buy the less expensive one myself. better yet the way I use breadboard I would buy 10 of them and save even more.
No kidding I have two powered breadboards and about 6 other regular breadboards with something on em and if I had more boards that would make my life or hobby much easier
have fun gogo -
hello privas
A rpm counter could be made with a ir led and ir detector. Using a 4017 as a counter and some kind of relay. BUT the thing is SAFETY the Power switch would have to be manualy shut off befor unloading the machine. I don't know what your setup looks like but if you go automatic I would sugest haveing a cage around it with a door with some kind of cutoff switch to kill the power when its open.
You could get more elaborate and drop the 4017 counter and use a microcontroller with a count down timer that could be set at any amount of turns you wanted. The relay is no problem, a simple circuit between the mcu and the realy would be easy. And maybe a triger setup for the door latch to reset the counter.
have fun
gogo -
Thanks Ashtead
This dose help, I have the uln2803 and th 2N3906's Now all I have to do is get the breadboard out and do some testing, As far as codeing the pic thats no problem I think I understand the asm code better then I understand the electronics part.
When I get the thing going and the code rem'ed I post it if anybody wants it.
Thanks again
gogo -
Sorry about that.
anyways you metioned the 2803 and 2003 right. did you mean uln2803 and uln2003? ones a npn transistor array and the uln2803 is a npn darlington transistor array right? I want to follow this read because I made a scrolling message sign with a Pic and three 74Hc595's. I made the led array out of a bunch of cheap red leds on a double sidded copper clad board. I put 220 Ohm resistors between the output pins of the 595's and the colloums. After adding the delay times to get the scroll right it worked but not very bright. So my next attemp will be with transistors added and I was thinking of using the uln2803 between the pic and the array. Not sure yet
What do you think
gogo
48Mhz Xtal
in Datasheet/Parts requests
Posted
Nice wizard
I check the places I buy from and they didn't even come close. I don't know why I don't use mouser maybe its there catalog to much info but ya they have just about everthing.
gogo
