cyw1984
63 -
Everything posted by cyw1984
Linear Voltage Regulator Design
cyw1984 replied to cyw1984's topic in Electronic Projects Design/Ideas
It is my new design for my circuit If LM358 is slow op-amp...which opamp should I use??? Also, how to add on somthing to improve this circuit . Such as capicator to reduce noise and zener diode make the voltage stable??? Thanks a lot -
i SEE....It 's 4.5M high speed Op- amp ....Is your design need remove 555 timer ?? Also, which P-channel MOSFETs and Diode do you used?? -
Then....Which op-amp should I use????? -
O...IC~~~ Can help me to remove the thing which not a voltage regulator....Thanks a lot
If I want to output 0-30V Vin =
Thanks audioguru, then which part is Voltage reference and linear Voltage regulator??? I would like to test one by one~~Thanks Is it all the part is voltage regulator?? Am I worng???
I remove the current limit part....Am I right??? also......... What is the function of the RED circle?? The diode may i repace the resistor there?? Which op amp I should use there???? thanks a lot
Is it OK?get any problem?? I am a newbie.....which part is current limit?? If i want to remove the current limit part...how to change the circuit?? thanks
How can this circuit improve 0...30V???
o...How to solve it??? which IC I should use?? Also ...how can it .....started voltage 3V change to 0V??? and can achieve to 30V -
Vout = (R1+R2 / R1) * Vref 5k >>>> 4k 1k >>>> 2k Is it OK?? -
Also...If the Vref 0-5V replace 0-10V how can i change the resistor and how to caculate??? thanks a lots -
It is a 3 to 24 V linear power supply how can this circuit improve 0...30V??? :P :P :P
Hello, I am sorry for my poor English...also I am a newbie of electronic... I really want to make this project for my first and serious project.. I want to ask somting abt this project...hope anybody can answer me...thanks you. 1. Which precise part is control current and control voltage..??How to separate them?? 2. I would like to separate to make it. How can i separate the circuit and test for it?? 3. If I use 0-10 V DAC's Vref to repace P1 and P2 ...how can i change the circuit..? please draw the circuit for me...please.. 4. And how to caculate the change part if I use another Vref of DAC?? 5. Does any body have a right schematic??? coz i read the post know that the original schmeatic have some bug Thanks for answering
I get a problem of 0-30 Vdc Stabilized Power Supply
cyw1984 replied to cyw1984's topic in Projects Q/A
O..thanks audioguru it's really complicated ???? If I want to set the output voltage and current limit with DAC's~~ How can i improve this circuit?? -
I have couple of questions of this project. http://www.electronics-lab.com/projects/power/003/index.html How could it change the P1 and P2 to be Vref for D/A convertor 0-10V and how to caculate the resistor???? Thanks a lot
