renaldo
12 -
Everything posted by renaldo
can any help me find a schematics for this tv sony trinitron (kv32xzr26) a80jyv10x or 50x
ok well can a power supply be build inside the inverter that would give you 12 or 48 volts and a nice high am which would keep the load off the batteries. with this the life time of the batteries would be much longer. the inverter would pull from the power supply instead of the batteries and i have this software that calculate the specs for you i put in what i want and it told me how much volts and size capacitors i needed well if you want it let me know and check it out and see whats use it could be
i think this could help with the project i found this site that has a 200w inveter http://www.mza.com/~seward/Laser_FAQ/www.repairfaq.org/sam/samschem.htm#schbp1 or this link http://www.technology.niagarac.on.ca/people/mcsele/i2k.htm
hello can pic be posted on this forum because i have a acdc power suply and i would like someone to look at it and see if i could use some parts out of it to build an inverter and it has a small inveter built in because the fan on it runs off 115vac but i dont know how much watts it is but if i could put pics up on this forum then someone could see what im talkin about
im not worrying about the bateries i have that covered i need to build a solid inverter im useint 12 400 amp batteries and a 90 am deep cycle charger so it dont matter to me how much it draws i have enough batteries to handel it
ok true what would be a nice size 4kw inverter
can i upgrade thats 500w to 5000w with a 110 and a 240 output ac
i would like to build an 6 or 7kw inverter and i need some help can anyone make up a schematic of it or send me a link where i could find the schematic for it
