71 -
Posts posted by GPG
The diode is protecting the auto black level sense transistor. Any low current high speed diode rated at ~200V will do.
What is this diode's function
They will all work in this circuit. The layout is far more important
ICL7107 Power Supplies
From the data sheet:
The ICL7107 is designed to work from -
Have you seen the one in our projects section?
http://www.electronics-lab.com/projects/motor_light/037/index.html
Does not look like it will take much modification to fit your needs.
Spark tansmiters were more honest. You can do it with a cheap cordless doorbell -
Q2 will supply current to the regulator
This can reach 2.5A -
Q2 will supply current to the regulator (until it smokes)
Yes
If the zener reads low both ways it is :'(
You say "I found the zener to be a 8.5v approx 1.5 A "
How did you test it?. If it has some writing on it tell us, and the values of the resistors -
The zener is the reference for the regulator.
When the voltage on the base of the transistor exceeds
the zener voltage plus Vbe, the transistor conducts
tending to remove base drive from the pass transistor.
So the regulated output is
(Vz + Vbe)*(1+R1/R2)
What are the original values? -
MJE800 is a darlington transistor
http://www.fairchildsemi.com/ds/MJ/MJE803.pdf
Does that make it look like the att. The unlabelled resistors are part of the darlington. -
It is possible to use the drop across your existing wiring to measure the current.
The way I have done it is to use a magnetic field sensor like this:
http://www.allegromicro.com/sf/0750/
I rolled my own using a sensor and a modfied rectangular ferrite core
salvaged from an old tv line drive transformer
The pot you have suggested remembers the last setting. How many channels do you need to control
analog input frequency counter with binary output.
in Electronics chit chat
Posted
How many digits/resolution? What type of output, BCD, LED, LCD?
