736 -
Posts posted by prateeksikka
hi audioguru!
my question still remains.what are these optocouplers.i only know one line pertaining to them "they have same relation to 2 ground points isolated from each other"which i could search from google.com
reply soon
prateek -
HI EVERYBODY!
CAN ANYBODY TELL ME WHAT ARE OPTOCOUPLERS ,PRINCIPLE AND WORKING AND APPLICATIONS????
PRATEEK -
hi buddy!
what kind of video circuit do u require?plz be clear
prateek -
audioguru!
though in any case i have only seen electrolytics caps exploding
ceramic capacitors just turn blackish if i apply high voltage across them
prateek -
hi audioguru!
what kind of program can do this job.anyhow ripple counters is an easy option can an 8085 or even my pentium desktop PC be used as a controller ?
what would be the logic for such a program?
prateek -
what kind of data do you wish to read from the sim ?
mind you your sim me get destroyed in the due process
prateek -
HI AUDIOGURU!
AC THROWS US AWAY BECAUSE I GUESS DIFFERENT FORCES DIRECTION B/W PARALLEL AND ANTI PARALLEL CURRENTS.]
(I GUESS)
MOREOVER AT OUR HOME AC VOLTAGE BECOMES ZERO ATLEAST 50 TIMES IN 1 SECOND.WHILE DC MAKES ME STICK TO THE LINE,NO CHANCE OF GETTING AWAY HENMCE IT IS MORE DANGEROUS!
RIGHT?YOUR COMMENTS
PRATEEK -
I KNOW THAT AN ELECTROLYTIC CAPACITOR HAS A POLARITY!
I AM SURE ON THAT POINT !
I CONNECTED IT RIGHT AFTER ALL,I LOST 2 CAPACITORS IN2 HUGE EXPLOSIONS.NEITHER ARISES A QUESTION OF HIGH BIAS BECAUSE I WAS CAREFULLY INCREASING IT WHEN I REACHED JUST 4V IT EXPLODED WITH ALL MATTER COMING OUT OF IT.YMMMMMMMM
CAN THE CAPACITORS BE FAULTY?
PRATEEK -
hi audioguru!
in any case which when according to you is more dangerous?
a 220 V AC OR A DC VOLTAGE OF SAME VALUE?
MY ANSWER(A GUESS) IS DC BECAUSE AC WILL ATLEAST ASSUME ZERO VALUE MANY TIMES IN SAY 10 SECONDS BUT DC WOOOOOOOOF!
WHAT DO U THINK?
PRATEEK -
hi audioguru!
i had started this topic of FM wave propagation because i had recently built an FM RECIEVER AT MY PLACE ,.it was designed to operate at 220Vac which was followed by transformer,rectifier and filters etc.
actually i had no transformer earlier when i was making it, out of curiosity,i connected only 4V dc (with fear in mind) after the filter directly
and you wont believe,one of my electrolytic capacitors of 470uF
exploded like a bomb! i changed it and put a 1000uF in its place i was shocked when i saw it exploding into pieces,however the circuit worked when i put the T/F in place and connected the mains supply
any comments on how it could happen?
prateek -
hi audioguru!
can i safely conclude that it is neither voltage,nor current but high power kills a person.high voltage and high current alone cant do anything .it is the power(voltage*current) which kills the person.
comments from all?
prateek -
HI AUDIOGURU!
THE FORMULA POSTED BY SHAHRIAR CLEARLY TELLS US THAT DISPLACEMENT CURRENT IS A FICTITIOUS CURRENT ASSUMED TO SATISFY THE EQUATION!!!!
(MAXWELL'S EQUATION)
SOME BOOKS ALSO SAY THAT NOTHING IS GETTING DISPLACED,THE NAME IS JUST A JAM DUMMY AND PURELY AN ASSUMPTION,YOU COULD CALL IT AS YOU LIKE BUT IT IS JUST A CONVENTION TO CALL IT A DISPLACEMENT CURRENT(FUNDAMENTALS OF PHYSICS BY RESNICK AND HALLIDAY SAYS THIS)
PRATEEK -
ANTE!
IF I CAN STAND HEALTHY T 29 mA,I GUESS EASILY I CAN TOUCH THE VERY HIGH VOLTAGE TRANSMISSION LINE WHICH HAS A FEW MICRO AMPERES FLOWING,CAN A MICROAMPERE CURRENT KILL A PERSON EVER?
PRATEEK -
hi all!
alun u r right transformers do cause some problem in winding but air cored inductors very easy to make!
i hv myself made some of them .fatal i can help u in that regard
u just need a piece of wire
prateek -
hi audioguru!
i must correct u on this point.in my country too ,F,M and AM bands are not used by army,the bands used by them fall into say 540-1600kHz which we vaguely called AM band (atleast in my country)
but thats what i meant by my point earlier,540-1600 kHZ IS NOT F ULLY AM some frequencies are missing and those are used by army .actual AM is say(hypothetical)
540-670
690-880
930-1600
these are assumed and not actual values values falling out of this range used by military
prateek -
HI AUDIOGURU!
WHILE SEARCHING ON THE NET,I FOUND THAT SOME OF THE SO CALLED MISSING FREQUENCIES ARE RESERVED FOR USE BY OTHER APPLICATIONS LIKE MILITARY ETC
COMMENTS?
U TOO SEARCH FOR A POSSIBLE REASON AND DO TELL ME IF U GET IT!
PRATEEK -
HI THERE!
WHATS A CB?
FOR WHAT APPLICATION DO YOU WANT THIS INDUCTORS, I HAVE MYSELF MADE INDUCTORS FOR SOME OF THE APPLICATIONS.MAY BE YOUR APPLICATION FALLS IN THAT AREA ,IF YES U CAN MAKE IT ON YOUR OWN,ITS REALLY SIMPLE,BELIEVE ME!
PRATEEK -
can anyone tell me the names of common buses like PCI,ISA etc and the functions they perform?
my cam is not working so i cant post a pic of my PC -
HI EVERYBODY!
I OPENED UP THE CPU BOX OF MY COMPUTER FOR THE SECOND TIME
I COULD RECOGNIZE THE CPU CHIP ON THE MOTHERBOARD,A THICK BOOK TYPE HARDDISK!,AND A FEW OTHER BUSES.CAN ANYONE HELP ME IN KNOWING WHAT TYPES OF BUSES ARE THESE.THOUGH I KNOW A FEW WORDS LIKE ISA BUS,PCI BUS ETC.WHAT DO THESE BUSES ACTUALLY DO AND WHAT ARE THE DIFFERENCES B/W THESE BUSES.DO WE HAVE ANY OTHER BUS IN THE SYSTEM?
PRATEEK
AUDIOGURU!
HIGH VOLTAGE GENERATING HIGH CURRENT KILLS A PERSON.
A 2A CURRENT SOURCE ,WILL IT GIVE ME A SHOCK,IF NOT WHAT VALUE OF CURRENT SOURCE
(ASSUMED IDEAL) AND WHAT VALUE OF VOLTAGE SOURCE CAN GIVE A GOOD SHOCK?
PRATEEK -
hi MP!
AND OTHERS
I NUST ADD THAT BE CAREFUL TO CLEAR THE DATE AON THE PORTS BEFORE USING ANY INPORT COMMAND IN YOUR PROGRAM,AN EXCESSIVELY HIGH VOLTAGE PRESENT ON A PORT PIN ALONG WITH THIS CARELESSNESS CAN EVEN DAMAGE YPUR MOTHERBOARD(IT IS A PRACTICAL EXPERIENCE)
PRATEEK -
hi vaibhav!
u can very well work on projects like physical layout design(i.e how the components will be physically arranged on the chip),timing analysis,
delay analysis,micrtocontroller programs(if u have some knowledge of a programming language like C or atleast assembly language)
these u can do sitting at ur home on a PC!!!!
PRATEEK -
HEY GUYS!
WHATS THE PROBLEM IN USING AN INTEGRATOR CIRCUIT WITH FEEBLE AMPLIFICATION USING OPAMPS?
PRATEEK -
AUDIOGURU!
A FEW mA current is sufficient to kill a person .if i take a voltage source of 3V,short circuit it,a large,huge current will flow,even if i touch the wire at this point it wont even make me feel the current while a roomheater which has a few mA or hardlyA current can tear apart a person.ur comments?
prateek
OPTOCOUPLERS
in Electronics chit chat
Posted
audioguru!
can i call optocouplers as solutions to bulky transformers which do the same job?
prateek
