hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
I have Se-a900x
kdc-c800
http://www.mictronics.de/?page=cdc_proto#Kenwood
pin direction description
1 O CH-REQH - Request output to changer; "Low" : Request
2 - Ground
3 - Vcc +12V
4 O CH-CON - Changer control; "High" : Operation mode "Low" : Standby
5 I CH-MUTE - Mute request from changer; "High" : Mute
6 - AGND - Audio Ground
7 O CH-RST - Reset output to changer
8 I Audio right channel
9 I CH-REQC - Request input from changer; "Low" : Request
10 I CH-DATAC - Data input from changer
11 O CH-DATAH - Data output to changer
12 I Audio left channel
13 I/O CH_CLK - Clock input/output for changer
ftp://docs.kenwoodusa.com/manuals/OM-KDC-C800-1992-KUSA.pdf
http://www.minidisc.org/manuals/kenwood_kmdps970r.pdf
http://instrukcje.elektroda.net/caudins.htm -
Search Results
uPD6250C
Sony KV2670R
uPD6250 17x16 DIP16 uPD6250C NEC
Remote Control Memory IC
Troubleshooting Guide
http://www.mainelectronics.com/servicetips/sonykv2670r.htm
UPD62 Datasheet
http://boss.iele.polsl.gliwice.pl/pdf/NEC/u14474ej2v0ds00.pdf
App Note
http://boss.iele.polsl.gliwice.pl/pdf/NEC/u11726ej1v1an00.pdf -
I Found the real Datasheet!
http://www.pgmfi.org/twiki/bin/view/Library/Oki6260A
Is it better than the one posted?
Please share. -
Nice Pinout picture
but, where does each pin go?
It would be nice to know Power, Audio, Programing, Ect. -
Not available yet try emailing NEC
Here are some more interesting Links.
Parabolic Microphone
http://ourworld.compuserve.com/homepages/G_Kunkel/microphone.htm
http://ourworld.compuserve.com/homepages/G_Kunkel/cardboard/cardboard.htm
Cardboard Dish
http://ourworld.compuserve.com/homepages/G_Kunkel/cardboard/cardboard.htm -
Will this work?
http://www.nteinc.com/specs/1300to1399/pdf/nte1389.pdf
http://www.elektronika.sirius.pl/index.php?dzial=aplikacje&id=074 -
The biggest was on a power pole but, it was only 2 ohms.
Here are some
Telephone Links
http://www.electronics-lab.com/projects/telephone/013/index.html
http://www.electronics-lab.com/projects/telephone/014/
http://www.electronics-lab.com/projects/telephone/015/index.html
http://www.electronics-lab.com/projects/telephone/016/index.html
http://www.geocities.com/iecmaster/circuits_tel/cir_tel002.html
http://www.ee.washington.edu/circuit_archive/circuits/F_ASCII_Schem_Tel.html#ASCIISCHEMTEL_010
http://www.geocities.com/iecmaster/circuits_tel/cir_tel007.html
http://www.electronicsforu.com/efylinux/circuit/feb2003/Simple%20Telephone%20Ring%20Tone%20Generator.pdf
http://www.techlib.com/electronics/telephone.html
http://www.hotspot.freeserve.co.uk/HOTSPOT/TLS/tlsframe.htm
http://www.hut.fi/Misc/Electronics/circuits/telephone_ringer.html -
LM383 TDA2002V UPC2002V ULN3701Z AE320
http://www.ozitronics.com/docs/k47.pdf
http://www.alldatasheet.com/datasheet-pdf/view/NSC/LM383.html
http://www.st.com/stonline/books/pdf/docs/1449.pdf
http://members.tripod.com/~Malzev/comp/tda2002.htm -
2sd1700 Datasheet
Your name does not do you justice.
I found the same project in 3 locations in my search for the Datasheet.
Finally after hours of searching I read the Circuit Operation Details.
Circuit Operation:
IC1 is an Infra Red module. IR modulated pulses are received and buffered by this IC. It has a standard TTL output, the output with no signal is logic 1. One gate of a CMOS inverter and drives Red LED1 as a visible switching aid. Another gate buffers the signal and applies it to the time constant circuit, comprising R3,C2,R4 and D1. C2 charges via R3, and discharges via R4, D1 prevents quick discharge via the low output impedance of the CMOS buffer.
I then realized the LED you seek is just a Visual Aide not anything special.
A standard LED will do the job just fine.
Here are my search Results.
CQX35A
CQX35A = TLHR5100
LTL4208=CQX35A LITEON 5Pie
http://www.zen22142.zen.co.uk/Circuits/Interface/ir_switch.htm
http://www.mitedu.freeserve.co.uk/Circuits/Interface/ir_switch.htm
http://www.electronics-lab.com/projects/models/008/index.html
TLHR5100 VISHAY/TE
LTL4208
general purpose visible dome-style led LITEON
LTL-4208-TN002
general purpose visible dome-style led LITEON -
Tuff one I found others in the series but not that one.
Electronic Compass
Posted
Try These Links!
Electronic Compass
http://users.frii.com/dlc/robotics/projects/botproj.htm
http://www-2.cs.cmu.edu/~danieln/digital_compass.htm
