hotwaterwizard
2,022 -
Calendar
Posts posted by hotwaterwizard
Not sure if this is what you need
it looks like a Doc Feeder Motor
http://www.precisionroller.com/doc-feeder-parts-for-canon-dadf-k1/details_33863.html -
Do you have any more info on this assembly?
It looks like it came out of an Encoder of some sort.
The black wheel on the back side is like a rotary Encoder wheel.
Google Search results Canon Precision motor CN38
http://www.canon-prec.co.jp/english/products/dcmotor/index.html
http://www.canon-prec.co.jp/english/products/dcmotor/pdf/DC_Micro_MotorsE.pdf
Canon Precision Encoder Motor
http://www.tridenteng.co.uk/media/pdf41739466eadb3.pdf
http://www.tridenteng.co.uk/media/pdf43030ed6f02e0.pdf -
Google search Results
VARO VSK3040T TO-3
NSN # 5961-01-338-3618 ,5961-01-217-0614
VSK3040T N/A Center-Tapped Positive CC Schottky Rectifier
CROSS Referance
MCC MBR3040
http://download.siliconexpert.com/pdfs/source/qd/mco/mbr3020-mbr30100(to-3).pdf
RECTRON SR3045C
http://www.asukaele.co.jp/hp/rec/data/sr3020c-3060c.pdf
Microsemi SD241HR2
http://www.microsemi.com/datasheets/WT2-48.PDF
Shindengen S30SC4M
http://www.datasheetcatalog.org/datasheet/Shindengen/mXqwqwu.pdf
http://www.datasheetarchive.com/
VSK3040T Spec sheet
Various
V(RRM)(V) Rep.Pk.Rev. Voltage=40
I(RM) Max.(A) Reverse Current=10m
@V® (V)(Test Condition)=40
I(RM) Max.(A) Pk. Rev. Current=75m
@Temp. ( -
I can do it with WinRar but what a hastle 8.2 mb 3 files per post I figure about 28 files at 300kb and 10 x posting just to get them on here.
Maybe I will go somewhere else to post my files and forget this place!!!!!!! -
1 post for that guy. never replied back. what a waste of my time finding them for a ghost.
Look in this file
This is rediculous I have the Service Manual but this STUPID BOARD is set for 3000kb
How many seperate files do I need for 8.2MB ???? -
This topic has been moved to Service Manuals.
[iurl]http://www.electronics-lab.com/forum/index.php?topic=19733.0[/iurl] -
http://www.freeservicemanuals.net
Check all of your solder connections and voltages to the device.
http://www.electronics-lab.com/projects/test/014/index.html
http://users.otenet.gr/~meteo/project_led-display-digital-voltmeter.html -
Try your local Library. Not kidding!
Okay it took me a while but here is what I found.
All 4 of them. 2 here and 2 more in the next post. -
74188: 256-bit (32x8) Programmable read-only memory with open collector outputs
74287: 1024-bit (256x4) Programmable read-only memory with three-state outputs
74288: 256-bit (32x8) Programmable read-only memory with three-state outputs
74387: 1024-bit (256x4) Programmable read-only memory with open collector outputs -
Looks like Stuee lost interest in this post.
http://www.kcdec.com/download/2008918111259.pdf
http://parts.digikey.com/1/parts/989394-sensitive-gate-scr-0-8a-600v-low-ec103m2.html
http://www.teccor.com/data/en/Data_Sheets/E5SensitiveSCR.pdf -
a magnet and 5 reed switches could do it low tech.
I Googled it and it sent me streight back here. LOL ??? :) ;) :D ;D >:( :( :o 8) ::) :P :-[ :-X :-\ :-* :'(
The model number would be helpful.
Maybe these links will be helpful to you.
http://www.repairfaq.org/sam/crtfaq.htm
http://www.electronixandmore.com/project/7.html
http://www.tone-lizard.com/Oscilloscopes.htm -
M455E Ceramic Filter?
http://www.alldatasheet.com/view.jsp?Searchword=M455E -
Possible Substitutes?
http://kr.ic-on-line.cn/IOL/datasheet/actf45-48_4171619.pdf
LM338 Power Suply Current Regulator
in Datasheet/Parts requests
Posted
Exactly what are you wanting to do here?
You Must Heatsink the components for 5 amps each if not they will only handle 1 amp each.
There is another way to make a high current power supply.
