hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
Try Some of these Links!
http://212.57.231.17/datasheetarchive/Datasheets/Zarlink_Semiconductor/DS111367.pdf
http://w1.859.telia.com/~u85920178/tx/qrp-hf1.htm
http://www.nrgkitsfm.com/workshop/early_stereo_5watt_pll_radio_jukebox.htm
http://www.commlinx.com.au/rf.htm
http://www.arrl.org/tis/info/qrpprojs.html -
Yes it is 2N278
TO-36 PNP GERMANIUM 15A 50V
DELCO#5490810 hfe=50@1Amp -
http://auctions.searchmarketing.com/default.aspx?semsearch=hpm+900&submit=Search
Try this.
Use DC Voltage while doing this Experiment.
Lets Use a 12 volt battery and a 12 volt Relay.
Touch you fingers across both the Positive and Negitive of the battery.
Nothing, no fealing.
Now Connect The Relay Coil Across the Positive and Negitive terminals while touching the wires.
Same Thing Until you remove the wires from the battery while holding one wire in each hand.
You can feal what happens to the Transistor when no diode is there. -
Check out Our other Post on the subject.
Drag Lights For Dogs Click Here
Here is a simple solution.
Just leave out the loop wire!
http://www.redcircuits.com/Page72.htm -
I just use an Ohm Meter or a Signal Generator.
You could Make a Fox-Hound Circuit.
Using RF
http://www.uoguelph.ca/~antoon/circ/foxhound.html
Using AF
http://www.pic101.com/foxhound -
Check out these Sound Energy Links!
http://www.fon.hum.uva.nl/praat/manual/Sound__Get_energy_in_air.html
http://fusionanomaly.net/soundwaveenergy.html
http://www.rense.com/general/soundwaves.htm
http://www.sciencetech.technomuses.ca/english/schoolzone/Info_Sound.cfm
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/reflec.html
http://www.recordingeq.com/EQ/req1100/wave.htm
http://www.physics.usu.edu/classes/4020/soundnotes/sound.htm
http://www.newi.ac.uk/buckleyc/sound.htm
http://www.cnn.com/TECH/9712/02/sound.wave.energy
http://www.macrosonix.com/pdf%20files/Physics%20Today.pdf -
SFC2723M
Cross Referance Part Numbers
TDB1146 SFC2723 LM723 UA723 MC1723
http://matthieu.benoit.free.fr/cross/t.htm
http://www1.jaycar.com.au/images_uploaded/LM723.PDF
http://perso.club-internet.fr/f5jtz/pjacquet/jtz723.htm
[attachment deleted by admin] -
Mouser and Digikey both have this IC in stock and by Many Manufactures
Here are my search results.
http://www.isocomoptocouplers.com/4N29.HTM#package
http://www.fairchildsemi.com/ds/4N/4N30.pdf
http://www.mouser.com/index.cfm?&handler=data.listcategory&D=78-4N32&terms=78-4N32&Ntt=*784N32*&Dk=1&N=0&crc=true
http://www.optocomponents.com/datasheets/db90048.pdf
http://www.datasheetarchive.com/181.html
http://www.web-tronics.com/4n32.html
http://www.vishay.com/docs/83736/83736.pdf
http://www.digikey.com/scripts/DkSearch/dksus.dll?KeywordSearch -
Is there a ST5512 involved? I have a complete Manual for it 205 pages!
Here are some links I came across.
http://www.classiccmp.org/transputer/languages.htm
http://www.bbk.net.cn/user/revercengineer/downloads/uploads/ST5512ds0300.pdf
http://www.classiccmp.org/transputer/documentation/inmos/4944.pdf -
J'ai besoin de plus d'information.
eXACTLY WHAT ARE YOU LOOKING FOR?
Do you want the Module already made or do you want a circuit so you can make one?
Here is a Power Schematic
Here is a Phone Project that Uses this IC
http://electronickits.com/kit/complete/tele/ak-700.pdf
Here is the Datasheet! -
Here are some from the web.
Electronic weighing system
Posted
Why not use a Timer to stop the Screw from turning after a certain time..
Use an adjustable Delayed off timer and just keep weighing the powder until you get the desired weight for the time you set. Then it will dispense the powder according to the limit you set.
