hotwaterwizard
2,022 -
Calendar
Posts posted by hotwaterwizard
You could install a preamp on the input.
Like they had on the old Record players -
If you want help you have to give more information Make Model etc
A search on Google has almost no results, Just tells you what it is and what it does.
Perichrom PR-2100
http://www.instrument-solutions.com/perichrom/pdf/pr2100.pdf
http://www.dizgeanalitik.com/PERICHROM_bio.pdf -
I found only this on a search
http://www.ebonne.com/sm/PS3-service-manual.pdf -
You could just buy a karaoke and use the circuit in it.
Here is the LM86 Datasheet http://download.siliconexpert.com/pdfs/source/qd/nat/lm86.pdf
Now I know why you are the way you are.
They call it Wisdom.
Do you know the difference between Knowledge and Wisdom?
Knowledge is knowing what to do.
You learn from school and books and you have Knowledge.
Wisdom is knowing what not to do with the Knowledge.
You learn (from the school of hard knocks) that certain things you are taught in school do not apply in real life. Therefore you have Wisdom. -
Haven't found DTVS888
But here is ks9284 datasheet -
How old are you Audioguru?
How about this one?
http://www.uoguelph.ca/~antoon/circ/ps3010/ps3010a.html -
I have a Kenwood that is 18 watts per chanel and it works great.
The added benifit is I can still hear -
Here is one I found on a web search
Do you have the security code?
Won't work without it.
Just read SMD eeprom , and you have code in 5 min
You have to have the tool to read it.
Try 8536 -
Have you ever seen low voltage lighting in someones yard?
They run over 100 feet and they do not use regulators at each junction.
They use a large wire. You could ground the negitive to the tower and run one wire up to the lights.
Voltage Drop Calculator
http://www.powerstream.com/Wire_Size.htm
http://www.csgnetwork.com/voltagedropcalc.html
LED info
http://www.quickar.com/ledbasics.htm -
Last one.
You must download all 11 files then open from number 1. -
3 and 2 Rar file containing a Large PDF
5 and 4 Rar file containing a Large PDF
7 and 6 Rar file containing a Large PDF
9 and 8 Rar file containing a Large PDF
Here you go There are 11 parts total. Parts 11 and 10.
You must download all parts before you open the file. -
Thbis is a Diagram with a Transistor as an amplifier.
Here is what I have.
BBC Micro User parallel Port pinout
Search Results
http://64.233.167.104/search?q=cache:6oS1QMzr0EMJ:gja.space4me.com/things/Recovering_My_BBC_Micro.html+BBC+Micro+User+parallel+Port+pinout&hl=en&ct=clnk&cd=5&gl=us&ie=UTF-8
Pin Pin
(9 P) (25 P) PC BBC Pin
5 7 0V (Ground) Gnd (Ground) 1
2 3 RxD (Data in) -------------- TD (Data out) 2
3 2 TxD (Data out) -------------- RD (Data in) 3
1 8 DCD ---+---------- RTS 5
6 6 DSR ---+
4 20 DTR -------------- CTS 4
7 4 RTS ---+
8 5 CTS ---+
(The +'s mean that locally on the PC DSR has to be connected to DCD and that RTS has to be connected to CTS.)
Pin numbering
PC: BBC:
9-pin D-type or: 25-pin D-type 5-pin Domino DIN-plug
(male)
_____________ ______________ _____
\ 1 2 3 4 5 / \ 1 2 . . . . . 13 / / \
\ 6 7 8 9 / \ 14 15 . . . 25 / / 5 3 \
--------- ------------------- | 1 |
\ 4 2 /
The views of these figures are all from the outside (the backs of the computers) into the sockets,
i.e. they show the wiring sides of the plugs.
Here is another one
http://www.rtrussell.e7even.com/products/bbcwin/manual/bbcwinf.html
BBC Micro PC
DIN Plug D25 Socket D9 Socket
pin A < -
SPAM Unauthorized Advertising.
I have deleted so many spam messages.
Most common Spammer
show111
show222
show4444
show5555
show7777
show8888
[email protected]
[email protected]
www.show-digital.com
I wish there was a way that moderators could vote off members or Ban members from their board. This person just keeps logging in on different names when one is deleted. If we could find the IP Address and lock it out from the website that would be a dream come true.
I got 6 messages in one day for spam and the common thing was (show)
Well show me a way to fight this problem.
I also see that our members list has more 0 posters than people that post.
I wonder if some of those are spammers as well.
datasheet
in Datasheet/Parts requests
Posted
http://www.sawtech.com.cn/showpic.asp?p_id=32&path=&pname=%E6%97%A0%E7%BB%B3%E7%94%B5%E8%AF%9D%E7%94%A8%E5%A3%B0%E8%A1%A8%E9%9D%A2%E6%B3%A2%E5%8F%8C%E5%8D%95%E5%B7%A5%E5%99%A8
http://translate.google.com/translate?hl=en&sl=zh-CN&u=http://www.sawtech.com.cn/showpic.asp%3Fp_id%3D32%26path%3D%26pname%3D%25E6%2597%25A0%25E7%25BB%25B3%25E7%2594%25B5%25E8%25AF%259D%25E7%2594%25A8%25E5%25A3%25B0%25E8%25A1%25A8%25E9%259D%25A2%25E6%25B3%25A2%25E5%258F%258C%25E5%258D%2595%25E5%25B7%25A5%25E5%2599%25A8&ei=vlC4SvvyGoWEswPTg4wV&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D%2522F45/48A%2522%26hl%3Den%26ie%3DUTF-8
F45/48A Cordless phones SAW Duplexer
Type ------------------------------- F45/48A
Center Frequency (MHz) ------------- 45.25/48.25
Out-of-Band Rejection (DB) --------- ≥ 37
REPLACEion Loss --------------------- ≤ 5
Passband Ripple (DB) --------------- ≤ 2
Temperature Coefficient ppm/℃ ------ -72
1dB Bandwidth (MHz) ---------------- ≥ 0.5
Package ---------------------------- SA01
