hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
Here is what I have so far:
The problem with this design is Current handling capability.
The project you are looking at is only about 5 amps and a 100 watt Amplifier needs about 20 amps. You should make sure the transformer is 20 amps or better and use about 8 of the 2N3055 transistors 4 and 4 hooking three in parallel with each original.
Also see my post on the subject.
http://www.electronics-lab.com/forum/index.php?board=22;action=display;threadid=222 -
The Ic has NEC as the manufacture UPC2506v
I need a data sheet on an Audio IC
UPC2506V -
Here are some more links to check out.
http://www.doctronics.co.uk/4013.htm
http://www.elec.qmw.ac.uk/staffinfo/davew/lab/ttl74.htm
http://www.faqs.org/docs/electric/Digital/DIGI_11.html
http://www.pcbcafe.com/BOOKS/SpiceHandBook/08_chapter07-02.php
http://wug.physics.uiuc.edu/courses/phys344/fall03/344exp/Lab2_TTL_Logic/Lab2_TTL_Logic.pdf
http://people.msoe.edu/~welch/summer/presentation.pdf
http://www.play-hookey.com/digital/decimal_counter.html -
Check out this website!
http://www.qsl.net/ns8o/Induction_Generator.html -
Sequential Flasher
Here is a simple circuit for sequentially flashing Christmas light strings or other similar low-power lamps. The socket symbols may be single bulbs or sockets for lamp strings. The load must be capable of operating from DC since the SCRs rectify the line voltage. The SCRs must be sensitive-gate types and must be able to handle the load current and line voltage. The 1uF capacitors are non-polar film types. A fuse is indicated and a GFI type of outlet is recommended.
Warning: This circuit should be constructed only by persons with the qualifications to work on and design high voltage circuitry. Necessary safety considerations are not indicated. All parts of the circuit should be considered "hot".
The circuit may be extended by repeating the pattern with the last neon lamp connecting back to the first through a capacitor. Although a quick breadboard was tested, this circuit is "experimental" and may require some tweaking for best performance. The flashing speed may be controlled by connecting a 100k ohm (or larger) potentiometer across the 10 uF capacitor and connecting the 1 meg resistors to the wiper. Make sure that the shaft is an insulated type. The 1 meg resistors may be lowered in value for faster flashing. -
Here is a PDF of a temperature controller data sheet.
http://www.ee.washington.edu/stores/DataSheets/linear/lm3911.pdf -
This is so cool how did you get the diagram to show it in operation with the timing in progress and working?
If you want to share your projects I'm sure we all could enjoy them if you post them on this page.
Search option is a great tool. However yours lacks something very important. The option to view the original post in it's original section and the replys to that post.
This link is Forbibben to non members. Is there a way to get the info without registering?
American Wire Gauge
AWG OHMS PER WIRE
SIZE 1000 FT. DIAMETER
1 .1264 .2893
2 .1593 .2576
3 .2009 .2294
4 .2533 .2043
5 .3195 .1819
6 .4028 .1620
7 .5080 .1443
8 .6405 .1285
9 .8077 .1144
10 1.018 .1019
11 1.284 .0907
12 1.619 .0808
13 2.042 .0720
14 2.524 .0641
15 3.181 .0571
16 4.018 .0508
17 5.054 .0453
18 6.386 .0403
19 8.046 .0359
20 10.13 .0320
21 12.77 .0285
22 16.20 .0253
23 20.30 .0226
24 25.67 .0201
25 32.37 .0179
26 41.02 .0159
27 51.44 .0142
28 65.31 .0126
29 81.21 .0113
30 103.7 .0100
31 130.9 .0089
32 162.0 .0080
33 205.7 .0071
34 261.3 .0063
35 330.7 .0056
36 414.8 .0050
37 512.1 .0045
38 648.2 .0040
39 846.6 .0035
40 1079. .0031
41 1323. .0028
42 1659. .0025
43 2143. .0022
44 2593. .0020
45 3348. .00176
46 4207. .00157
47 5291. .00140 -
They say you can open these Schematics with Protel 2.5
http://members.tripod.com/valveaudio/schematics.htm
Can any one figure out how? -
Power supply for AMP in CAR
Posted
Show me where to put these resistors.
