denci
86 -
Posts posted by denci
Where should i place the 1kohm pot3 for fine voltage regulation?
Tnx a lot!
What is wrong with my heatsink calculation in 5 post ago??
http://www.changpuak.ch/electronics/calc_23.php
With this online claculator i have got the same results ??? ??? -
I usually use this way to calculate the heatsink, it is wrong that way:
(130°C-30°C)/4.5W - (10C/W+0.3C/W) = 11,9°C/W -
So, what heatsink do you suggest, how much should be a thermal resistance, i have one heatsink with 5°C/W at home, which I intend to fix on housing of BD139.
I think that it is enought for condition in this stabilized power supply with max 5A current or not?? -
I calculated the heatsink wit aprox. 0.5°C/W thermal resistance for one transistor, how much must be that for three 2n3055.
What fun you suggest?? what dimension and voltage? -
So, this is my first post on this forum, first hi everybody!! ;D
I will make this project in near future therfore i am interested how to calculate total dissipation on transistor 2n3055.
I will use the 5A (REV3) version of this project, so i'll use three transistor and transformer 30VAC 210VA.
I need this calculation for calculate heatsink thermal resistance for three paralleled 2n3055.
Is this calculation is correct or not:
Pd = 5A * (40V - 0,55V - 1.35V) = 190,5W
i got 0,55 from total voltage drop of three 0,33ohm paralled resistor (0,11*5), 1.35 is voltage drop on shunt resistence R7 (0,27ohm*5A)
0-30V Stabilized Power Supply
in Projects Q/A
Posted
As we know power dissipation of one of three 2N3055 output transistor is aprox. 65W and recommended thermal resistance for heatsink for one transistor is (200-35)/65 - (1.5 + 0.2) = 0,84 °C/W, but how can i calculate the required thermal resistance of heatsnik for three same transistor with the same power dissipation?
Is ther any equation for this or is eought that i get the heatsnik with thermal resistance three times smaller than thermal resistance for one of each used transistor??...sorry for my english!!
TNX
