Showing results for tags 'electronic component'.
As informed by Rubycon, production of materials used in aluminum electrolytic capacitors has been discontinued Stopped in ongoing production due to transaction volume and difficulty drop. Therefore, we will also stop production of aluminum electrolytic capacitors below Φ8. We at Sun Life have a high quality alternative to the Rubycon line of products. The following small diameter series products of YMIN can completely replace the series products of Rubycon. Type Series Life(Hrs) features Rated Voltage Range(V.DC) Rated capacitance(uF) working temperature (°C) Chip Type V4M 1000 3.95mmLMAX, ultra-small products 6.3~100 1~220 -55~105 Chip Type V3MC 2000 Ultra-high capacity, low impedance, small product 6.3~35 220~2700 -55~105 Chip Type V3M 2000~5000 Low-impedance, thin, high-capacity products 6.3~160 10~2200 -55~105 Chip Type VMM 3000~8000 5mm high, thin product 6.3~500 0.47~4700 -55~105 Chip Type VK7 4000~6000 7mm high, small product 6.3~400 1~680 -55~105 Chip Type VKO 6000~8000 Small size 10~500 0.47~10000 -55~105 Chip Type VKM 7000~10000 Long life, miniaturized product 10~500 0.47~4700 -55~105 Chip Type VKG 8000~12000 long life 10~500 0.47~4700 -55~105 Chip Type VKL 2000~5000 High temperature resistance, long life 10~450 0.47~4700 -40~125 Chip Type VKL(R) 2000 High temperature resistance, low impedance, high reliability 10~50 47~3300 -55~135
- capacitor
- electronic
- (and 3 more)
CL220 is a high voltage, temperature-compensated, 20mA constant current regulator. The device operates at up to 220V, and is accurate to ±10% over a 5 - 160V range. The device can be used as a two-terminal, constant-current source or a constant-current sink. CL220 Features • 5.0 to 220V operating range (VA-B) • 20mA ±10% at 5.0 - 160V • 0.01% / °C typical temperature coefficient • Packages Types: - TO-252 (D-PAK) • Can be paralleled for higher current
Tenco Technology-Electronic Components Importer.We have professional electronic material engineer to provide technical support.To provide electronic components supporting services for electronic manufacturer,including electronic components,wire and cable,plugin/SMD LED,capacitance,resistance ect.Service customers from all over the world.Customers in need can consult.Service mail:[email protected]:jace wei.tenco.Website:http://www.tenco-tech.com?lt
