Showing results for tags 'pcduino to act as 3d printer control pc'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 1 result
  1. 3D printing is a quickly expanding field, with the popularity and uses for 3D printers growing every day. 3D printing can be used to prototype, create replacement parts, and is even versatile enough to print prostheses and medical implants. It will have a growing impact on our world, as more and more people gain access to these amazing machines. For normal 3D printer, you need to have a PC connected to it. In this tutorial, we are going to cover how to use pcDuino act as host controller, and install 3D printer control software on pcDuino. Install software ``Printrun`` Run ``Printrun`` Control 3D printer using pronterance 1.Install dependent software tools Run the following commands in sequence: “$sudo apt-get install git” “$sudo apt-get install mercurial” “$sudo apt-get install python-distribute” “$sudo easy_install pip” 2.Install WXWIDGETS Input command :“$curl http://apt.wxwidgets.org/key.asc | sudo apt-key add –” (If it prompted that there is no such command as ‘curl’, please install it first using “$sudo apt-get install curl”) Edit “/etc/apt/sources.list” Add the following content to it and save. “# wxwidgets/wxpython repository at apt.wxwidgets.org deb http://apt.wxwidgets.org/ dist-wx main deb-src http://apt.wxwidgets.org/ dist-wx main“ Run the following commands in sequence: “$sudo apt-get update” “$sudo apt-get install python-wxgtk2.8” “$sudo apt-get install python-wxtools” “$sudo apt-get install libwxgtk2.8-dev” “$sudo apt-get install libgtk2.0-dev” 3: Install driver for PYTHON serial port “$sudo pip install pyserial” “$sudo apt-get the install wx-common” 4: Install the required TK library for PYTHON “$sudo apt-get install python-pmw” “$sudo apt-get install python-imaging” 5: Download PRINTRUN and related softwares “$git clone https://github.com/kliment/Printrun.git home/Printrun” Download the latest version skeinforge from http://fabmetheus.crsndoo.com/, and create a folder named “skeinforge” under directory “Printrun”, and unzip the just downloaded package into this directory.
