Showing results for tags 'voltage'.
Good day, all 🙂 Recently, I have a system running at 62V max, 54V nominal based on voltage divider rule formula. I wanted to have a little alert LED, so I was thinking about using 10, 1kohm resistors, and adding the LED bewteen the 9th and 10th (or 1st and 2nd, if it matters), to get at most 6V and just a few mA. Is a better/easier way? Is this a really crappy way? Or is this a perfectly fine way? 😶 Voltage Divider Basic and Rule.pdf
- 2 replies
- electronic design
- led
(and 1 more)
Tagged with:
Hi everyone, newbie here! Trying to find a power supply for LED backlight strips off of an LCD television. I've stripped it down but can't see it marked clearly anywhere. There are 2 strips with 6 LEDs on each. Printed on the light strips is the following: GJ-2k17 CSP-315 Pitch 109 (614x12) -v2.1 O1T38-1 RJ94V-0 E349376 HY-AI YK 1825 Attached are photos Cheers for any help!
