Showing results for tags 'zigbee sensor temperature and humidity'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 1 result
  1. This product is a smart temperature and humidity detector,adopts extra low power consumption ZIGBEE wireless network technology, using MCU to the temperature and humidity intelligent processing, with functions of dust-proof, insect-sproof, etc. Ensuring the stability of the product from the design. With high precision temperature and humidity sensor built-in, it can perceive and report real-time temperature and humidity to APP. The product is suitable for environmental monitoring in residential, factory building, computer room, shopping mall, hotel, office building, teaching building, bank, library, as well as the warehouse and many other places. Features Operating voltage:DC3V (1 CR2450 button battery) Standby current:≤10uA Networking way:ZigBee ad hoc network Wireless networking distance:≤100m (open area) Operating temperature:-15℃~ +60℃; Ambient humidity:Maximum 95%RH Outline dimension:60x60x20.8mm Tutorial we will show how to interface Deepcam ZigBee Temperature and Humidity sensor using the Linker ZigBee gateway, and serves as a basic framework for home automation sensors application. Prerequisites pcDuino3B or pcDuino8 Uno x 1 ZigBee Gateway module x 1 Linker Base shield x 1 Zigbee Temperature and Humidity x 1 Steps 1. Hardware connection According to the following diagram to connect pcDuino3B, ZigBee gateway and other equipment. 2. Download the ZigBee gateway demo code Turn on pcDuino3B, open a terminal and download the zigBee gateway code from the github. We also need to modify the Download source files https://github.com/delongqilinksprite/zigbee_hum_tem.git Note: You have to install pyserial in the system. 4. Add the Temperature and Humidity sensor Run the zigbee.py program get temperature Press and hold the RST pin hole of the Temperature and Humidity sensor until the green LED blink fast. Now we can start to add device and run the code: change the code line 226 <code>python zigbee_tmp.py </code> Run the zigbee.py program get temperature change the code line 227 <code>python zigbee_tmp.py </code> 5. How to add more ZigBee devices Follow the steps above, we have been able to add a device, and we continue to add other devices. but we shuld use another code program and more information ishere: More sensors can be found at here.
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
