kumar_prashu Posted September 19, 2004 Report Posted September 19, 2004 Hello I m trying to make a variable voltage Rectified power supply using LM338. But i am facing an unusual problem of ripple at the output of LM338. when I set the Output at the particular voltage, the ripple current at the output just doubles the DC value. just as if DC o/p = 12 volts. AC o/p = 24 volts.The exact specs. of the components are as follows:Transformer- 220/15-0-15 volts, 5 Amps. (center tapped)Diodes- MIC 6A4 Cap.- 10,000 microfarad /25 volts.(at the o/p of rectifier)large value is just to keep the low rippleLM338: 0-5 Amps. input- output differential voltage = 3 voltsWhy do this happens.pls explain.I want to completely remove the ripple content. Quote
MP Posted September 19, 2004 Report Posted September 19, 2004 How are you rectifying this voltage? Post a schematic.MP Quote
