ntquartex Posted December 29, 2004 Report Share Posted December 29, 2004 How can we design mod 60 counter with only 7493 or 7476 FFs. Quote Link to comment Share on other sites More sharing options...
EnigmaOne Posted January 4, 2005 Report Share Posted January 4, 2005 This may be a handy reference for you:http://www.pnc.edu/te/ecet157/LabReps.PDFwhich deals with 7476s.In short, you'd do a mod-10 counter implementation with 7476s, overflowing to a mod-6 counter implementation.Reset is the same as would be accomplished with a decade counter, but the NAND-ing (use 7400s) would be wired for a reset at a binary count of 0110.Considering the state of each Q and Q' at various count conditions, view the counter cascade as a whole, with an eye toward the reset condition for each counter stage. The solution should then be fairly obvious to you. (As in a program loop, the trick lies in specifying the terminal condition.)If you have problems figuring it out--which you should really try to do on your own first--post back and I'll give you a bit more information on the matter.[sp&g mods] Quote Link to comment Share on other sites More sharing options...
