Chandus Posted April 13, 2005 Report Share Posted April 13, 2005 Hi, guys, I just find this page, and is an amazing one. ;DI've got a problem with this kind of circuit, I'm thinking a dimmer could solve the problem, just one thing, I need to control the power from 0-100% with one voltage input of 6.67V max, so I want to know your opinion, if you think that a dimmer of 15A would work fine or some other circuit, I thought also of a saw tooth signal with a reference of 6.67V max controlling a Triac based circuit :-\. If you can aid me with circuits diagrams I would be pleased, thanks. :) Quote Link to comment Share on other sites More sharing options...
Chandus Posted April 14, 2005 Author Report Share Posted April 14, 2005 I didn't give full details, the main supply voltage comes from a 220V line, and the resistance is of 16.1Ohms with a current of 13.6A. Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted April 15, 2005 Report Share Posted April 15, 2005 hi chandus!welcome!!!why are u not using a variac for your mains supply?If that is not acceptable u can use a pot in series with your resistor. But i am unable to understand one thing.where are u getting 6.6 V with 220V input?However i guess u dont need a triac or SCR for such a simple application.:Dprateek Quote Link to comment Share on other sites More sharing options...
Chandus Posted April 15, 2005 Author Report Share Posted April 15, 2005 Thanks! I've got my welcome when I saw some really good topics around.........About the 6.6V, well, they are outputs of a National Instruments tool, FieldPoint, which you can vary from LabView from 0 to 6.67V, and that's why I want a mechanism to control with 0V-0W and 6.67V-3kW or something near to those values. I'm a newbie in power electronics, so I don't know if a variac could solve my problem, thank u for your answer. ;D Quote Link to comment Share on other sites More sharing options...
Chandus Posted April 15, 2005 Author Report Share Posted April 15, 2005 I'm thinking in something like the block diagram in the image, but I have issues about the way the PWM is going to use the phase obtained by the transformer, how do I take the phase into consideration in an op-amp circuit? There's also the consideration of the Vref coming from the FieldPoint and the circuit tolerance to the high current of 13.7A. Please add any comments.Triac_con_control_de_fase.rar Quote Link to comment Share on other sites More sharing options...
