dustin02rsx
- May 18, 2011
- 36
- Joined
- May 18, 2011
- Messages
- 36
Hey guys, im working on a project where i want be able to manually clock and manually clear a 74163 synchronous binary counter.
My problem is, every switch i use, i have to press a lot to even get a reading, then when i get a reading its not always accurate. it will count 1-2-3-12... and so on. I am not using the load feature.
I have built several circuits using this IC in class on the trainer that uses a "pulser" switch to clock. I believe the "pulser" switch is a momentary toggle switch. I do not know if it is N.O. or N.C. or how it is hard wired in the trainer. Furthermore i have built many circuits like this on an altera board and used a pushbutton as a clock.
I cannot get this circuit to work correctly on my breadboard at home and dont know why! Its summer break and i really dont want to bother my professor
I have tried a momentary N.O. pushbutton, a tact switch and a regular toggle switch with no luck. Here is my wiring. Any advice to get this working would be extremely helpful!
