davelectronic
- Dec 13, 2010
- 1,087
- Joined
- Dec 13, 2010
- Messages
- 1,087
Hi all.
I have been googling round to try and estimate an 85 Deg C, 35 volt 2200uf electrolytics capacitors life span, i can only get approximates in time.
I was trying to work out the life of the capacitor in a very small power supply.
Detail, power through or drawn from the supply, 350ma standby for 18 hours a day, but in those 18 hours a day the current draw increases to 1.2 amps for 15 minutes 3 times in that 18 hour period, so 45 minutes of 1.2 amps in the 18 hours.
The rest of the time the units off, the other 6 hours, making up the 24 hour day.
The voltage is a constant 13.50 volts, the capacitor is in an environment of a temperature of 40 - 50 Deg C, at peak current times 50 C and at standby about 40 C .
All i can find is max hours at max working temperature, not much help in determining its life span, the input voltage after rectification and the capacitors filtering is 19 volts, does or can any one give me an idea on it life span, approximately, ok why bother, well i am going smaller and smaller with a psu design, the capacitors environment is becoming small, and as a rough idea i was looking to find out the life of the capacitor, going on the above basic statistics, if its possible to work out a rough estimate of its life.
Its being used in an audio communication power supply. Dave.
PS any ideas would be valued as a design guide for future projects, if the unit needs to be seen i can upload a picture of the psu.
