Hello folks I have an old chess computer that I have lost the power supply for, I intially thought it would be straight forward enough to find a replacement but not so.
The original specifications are as follows.
Input: 240 VAC 60 Hz, 30 watt
Output: 6 VAC @ 1.7 Amps / 12 VAC @ 1.7 Amps
Originally intended for Milton Bradley Games. The enclosure and the 6 ft. cord are black.
Output cord has 3-pin overmolded connector.
The computer connection does have a 3 core input of red, yellow and black wires. The red goes straight to the motherboard on to terminal 1 on the P1 connector block and the black and yellow go to the switch which has a 24v ceramic capacitor soldered between the 2 terminals and then after the switch to terminals 2 and 3 respectively on the same P1 connector block as the red wire went to.
I think it will be a dual output supply giving 6 VAC, 12 VAC and 0 Volts but I am not sure which wires are doing what.
Would it be possible in the event of not being able to source a power supply to match the original spec to rewire the incoming to use 2 supplies, one 6 VAC & one 12 VAC ?.
Any help would be much appreciated. Thanks.
