Hi.I'm having a problem with my pendulum clock. the pendulum won't swing anymore I have this mantle clock which has a battery operated circuit which makes it's pendulum swing as a bobbin coil passes a permanent magnet. the power supply is 2 AA batteries. they are connected to a small circuit board. the components on the board look like 2 transistors, a 10v 47uf capacitor, some diodes or resistors, and a bobbin like coil. what would be the most likely component on the board that has failed? is there a schematic available similar to this design anywhere so that I might get all new parts for the board? thanks for any help
