Traffic Signal Project
Ravenvalor
Jan 21, 2012
3
Hello,
> I would like to build a board that has 1 - 120volt/600Watt input and
> 3 - 120volt/200Watt outputs. The outputs we shall call A, B and C will
> each light up a 150 - 200 watt light bulb. Each light bulb will light
> one at a time starting with A and ending with C. This will operate
> continuously. The delay between each output will be from .25 seconds
> to 2 seconds. If you think that there is something already out there
> that can do this I would like to know about it. I would like for this design to be robust enough to run 24/7/365.
> Thank You,
> Jim
Raven Luni
Oct 15, 2011
798
But if you want to do it yourself heres 1 way:
1. Have 3 555s in monostable mode with the outputs and inputs connected in a ring but also have the inputs pulled high and connected through a capacitor to ground so they cant be held low and will retrigger. Use relays to drive the high voltage lighting side.
Ravenvalor
Jan 21, 2012
3
Hello Raven Luni,
I was wondering if I could pay you to design something for me possibly?
I need to put a device into a traffic light and it needs to be robust enough to run 24/7/365.
It needs to power three 120-volt 150-watt lamps.
Thank you for taking the time to look at this.
Jim
Raven Luni
Oct 15, 2011
798
As much as id like to take your money, I'm just a hobbyist. There are people here far more qualified for that. Plus I've never worked with mains powered circuits. It's straightforward enough but I cant take that responsibility.
duke37
Jan 9, 2011
5,364
I built a traffic light sequencer some months ago, running on 12V and driving 12V bulbs.
The sequence was the UK sequence.
This could be modified to switch 120V with relays or triacs but I, like Raven Luni, am not going to get into the safety problem.
I will look up my posts to find the diagram.
duke37
Jan 9, 2011
5,364
The sequencer I made was based on a 4093 oscillator and 4017 ring counter. The 4017 has 10 outputs which are selected with diodes to drive the three fets.
Diagram attached.
