how to convert analog output voltage (3V to 5V and 4.6V to 5V) to (0V to 5V)
maxima_diesel
Feb 16, 2012
3
Hi I just wanted to convert the output voltage of the circuit I have made to a wider range of 0V to 5V. I would need this output to be analog, so the output shouldnt be 0V OR 5V. I have two circuits, the first one's output range is 4.6V to 5V and the second has a range of 3V to 5V. How would you change those output to 0V to 5V?. Thanks a lot in advance.
duke37
Jan 9, 2011
5,364
Give us a diagram of your circuits so we can advise.
What is the input voltage range?
maxima_diesel
Feb 16, 2012
3
setup: http://letsmakerobots.com/files/user..._Schematic.jpg. I've to modify that circuit because the IR emitter is not connected to a microcontroller in my design, and the analog output is not connected to a microcontroller either. With this setup output is definitely analog but the range is 3V to 5V, but I need an analog output to be 0V to 5V. thanks for your reply
