10 LED string.
TbirdMan
Apr 17, 2011
36
Ok, I am putting some super bright red LED's in my computer case for lighting. after playing around with different arrangements I came up with this, I just wanted to know if I missed any potential problems.
Data sheet is here:
What i can gather:
current is 70mA
Vf is 2.5V
70mA seems an awful lot.
Do you have the specs on these LEDs? 20mA is probably closer to what I'd expect unless they're a high powered LED.
War_Spigot
Feb 20, 2012
43
He did say super bright in his OP, but 70mA does seem excessive.
Solution 2: 2 x 5 array uses 10 LEDs exactly
+12V
+ -|>|- -|>|- -/\/\/\- + R = 100 ohms
The wizard says: In solution 2:
each 100 ohm resistor dissipates 490 mW
the wizard thinks 1W resistors are needed for your application Help
together, all resistors dissipate 2450 mW
together, the diodes dissipate 1750 mW
total power dissipated by the array is 4200 mW
the array draws current of 350 mA from the source.
from http://led.linear1.org/led.wiz
War_Spigot
Feb 20, 2012
43
The LED wizard said it would dissipate 4.2W at 350mA, so depends on your power supply, I suppose.
Guess I forgot the link for the Data sheet:
Yep, so 70mA seems fine. :)
You may be able to get lower dissipation by placing three in each string, but given the environment, I'm not sure it would make that much difference.
