Yes this is what I meantOne pin type or bayonet bulb the two terminals are the silver/grey bumps at the bottom not the side case
Unfortunate it was OL Mega ohms readingTest across the bumps and see should get reading
Do you mean continuity ?this is why I use the diode test feature on the meter.
HiIt will either work or not, this is why I use the diode test feature on the meter. It will give an audible sound when there is continuity and no sound when there is no continuity.
on DMM Push the select key to .))))) continuity (not --<I- diode) try to test both fridge lights bulb, non of them the buzzer sounded!!!!!!!
Hi
Today I have done this test with two fridge light bulb same as the one below :
http://www.wickes.co.uk/philips-40w-ses-cooker-hood-bulb-pk2/invt/218920/
One light bulb burned out for sure and other is working (for sure it is working)
BeepsTurn on continuity touch probe tips together what happens?
Beeps
Okay that makes sense.Some Multimeter unable to emit sound if measured resistance was below required resistance for buzzer sound or continuity test. Mine was 40 Ohm. That is, it will measure 106 ohms for working bulb but will not emit beep sound.
then I would expect the continuity test should beep for the working bulb , but that didn't happen !!!!!
