I'm clueless as to what you're doing or why you're doing it.
Simple. We are converting from incandescent bulbs to LED's which draw approx 180mA as apposed to 1157's which draw around 2.1A on the brake/turn side. So the issue is because the LED draws such a low amount of current the flasher relay does not work as expected. The bimetals heat slightly then cool quickly so the rate is extremely quick. By adding a 5.6OHM resistor it simulates a regular bulb and the flasher relay then works as expected.
The real issue becomes cooling that resistor. Using a wirewound cement style resistor even at 35W does not work unless you find a way to cool it. They run away thermally until they open or catch fire.
I know the normal way people do it is by replacing the flasher relay with a solid state flasher specifically for LED that does not care about load. The issue here is the flasher relay is built into the BCM (Body control module) which makes that impossible in this situation.
So... In short I need a better way. I have found a 6OHM aluminum resistor with mounting holes I am going to try. By mounting it to the frame I am hoping there will be enough heat transfer to solve the issue. The next issue is going to be ambient temperatures. Here where I live it gets easily to 105 during the summer. Tucked away under a cowl or hood etc the temperature will even be higher. So the thermal capabilities of the resistor itself coupled with the hotter then normal heat may cause either the resistance to be too far off or it to again run away thermally until melt down.
So again I was hoping someone would have a better way for this. Short of putting a light bulb in a box and venting it!
My next questions/thought is I know that some cars have ECU (Engine control module) that can tell when an injector goes bad. These types of cars that get performance mods like and external ECU have to have some sort of flyback circuit in them to simulate the load to the ECU so it thinks the injectors are working correctly. Would something like this work here? I know nothing about those types of circuits hence why I am asking here. It would be nice to have a solution that does not need serious cooling to implement.
