Clap clap switch
neba3939
Mar 15, 2012
9
Hi everyone, i am trying to build my own clap switch..
i found this schematic on Google and i liked it.
But i believe this schematics works only with a single clap.
what do i have to do to make it double clap switch(clap- clap ON, clap clap OFF)
thank you for your time..
duke37
Jan 9, 2011
5,364
That circuit looks to me to be one clap for on and the next clap for off. If you want it to respond to a double clap then a considerable amount of extra circuitry will be required and you will have to define what a double clap is.
neba3939
Mar 15, 2012
9
can you help me setup the extra circuitry... and the defining of "double clap"
My definition of double clap would be a single clap. In that case the circuit works as it is.
Alternatively, a double clap is two claps. This circuit with an additional divide by 2 on the output would suffice.
Note that I don't think either of these definitions would make you happy.
You probably mean a double clap is two claps more than a certain time apart, and less than another time apart. Now things get more complex...
You could do it with a microcontroller (in addition to parts of what you have in your circuit above, but with very significant changes). If you've never written any software, that route may be quite tricky too.
There's lots of variables and we really can't define things for you.
duke37
Jan 9, 2011
5,364
It is up to you to define what a double clap is, I would suggest that it is a double clap if the second clap arrives within a second of the first clap.
I do not have the time to design a circuit, you need to generate a block diagram to define what you want to do and then design circuitry to make each block work.
CMOS chips would be easier than transistor circuits.
A lot of peple here would do this with a microcomputer but I am not into that technology.
CocaCola
Apr 7, 2012
3,635
Yep, I would do it with a micro, but has been said you need to be familiar and capable of writing the firmware to do what you want or else it's a useless option... A simple adjustable threshold sound detection circuit interfaced to a micro and you are good to go...
neba3939
Mar 15, 2012
9
first of all i would like to thank everyone who answered my questions...
the thing is, i never wrote any program or firmware before..
i dont even know how to write them..
so i would really be happy if someone could show me.. if know can you suggest a book or anything that can teach me how to write the program.
thank you
steinklatre
Nov 29, 2011
29
neba take a look at the Arduino Uno board. Its a pretty straight forward easy access micro and I have had a lot of luck learning on it.
CDRIVE
May 8, 2012
4,960
By this definition, including Steve's comments about time between claps, I think we can do this by rectifying the mic audio and adding an RC time constant to the base of the mic amplifier transistor. The cap would have to receive another clap within X period of time to produce enough forward bias to turn the transistor on.
Chris
