Help on clap switch
neba39391
Mar 19, 2012
10
Hi everyone, i am trying to build my own clap switch..
i found this schematic on Google and i liked it.
But i believe this schematics works only with a single clap.
what do i have to do to make it double clap switch(clap- clap ON,  clap clap OFF)
thank you for your time..
Hero999
Oct 28, 2007
2,433
The transistors driving the LEDs form a divide by two counter which changes state on every clap. The counter is triggered by a pulse AC-coupled to the emitters via a 100nF capacitor. All you need to do is add another pair of transistors in the same divide by two counter configuration before the transistor which drives the relay.
It would make it easier to explain if all of the components were numbered i.e. Tr1, Tr2, C1, C2 etc.
Here are a couple of links to other websites showing a similar circuit.
http://www.electronics-tutorials.ws/waveforms/bistable.html
http://ch00ftech.com/2012/07/10/transistor-clock-part-2-prescaler/
mendimano1
Dec 31, 2008
59
Hi neba 3939, this is an intresting project, i dould like to try this project, is it posible from you to post the values of components, for diodes for example.
Hero999
Oct 28, 2007
2,433
The unlabelled diodes aren't critical. You could use the 1N4001, 1N4148, 1N4448, 1N914, BAV20 etc.
mendimano1
Dec 31, 2008
59
Thanx for help Hero999, i wonder if is it posible from you to post a scetch shematic of this.
Hero999
Oct 28, 2007
2,433
Try to figure it out for yourself. My description should give you plenty of clues. Post the circuit and I'll check you've got it right.
