There is the 'locate', which is a checking in mode and is quoted at 9 months working life for this mode and 'alert' mode which is the 2 month estimate.
having said thatwe know it has 2 ic's... but don't know what sort...
I fail to see those run numbers on their site it says 2-5 months in locate and hints at much shorter if in alert mode... From what I gather in 'locate' mode you can adjust the ping frequency from 10 seconds to 1 hour between pings... That 9 month run time (if valid) is certainly an estimate with the ping only happening every hour... So if we work the math again, 1 ping an hour is 24 pings a day, or about 6480 pings over the course of 9 months... Again we are at Apple to Oranges with you wanting to do 25200 pings a day, you still won't even get one days worth of run time, maybe a few hours...
Batteries have a limited amount of power, if you are transmitting you are using said power, and you will gobble up coin or button cells limited power in no time flat... There are ways to stretch this out but as I said your requirements and what is necessary to stretch run time out are at opposite ends of the scale... This is a physical limitation and has been a BIG hold up on miniaturization of many devices... We have improved batteries to some degree, and we have drastically improved the power requirements of many circuits, but there are still some rules and physical barriers that can't be broken with our current understandings and abilities...
A micro and a radio chip likely... The radio chip could have other integrated stuff, like a compose or what not to aid in location... That is likely the one they defaced to make it a little harder to identify as it's likely an over the counter chip... With a unit in hand and a little research you can likely identify the chip in a few hours time, same with the other chip that isn't defaced...
poorfornow just onequestion.. you say it needs to recieve signals 4 times aday... is this at a set time???
if so we could possibly have the unit shut down for say 5hours 55minutes on for 5minutes detecting for signal every 2secondsthen off again saving a crap load of battery.
another thing is unless yougive us more info we are kinda stuck. you keep referencing loc8torbut if that worksthen heck mod it. if you need something totally different then you have to give us more info
we should realise two things.
I am still trying to determine how it works
the issue here is that we have a rough idea of the loc8tor system.
we cannot give exact details without getting one, pulling it apart and going through it piece by piece.
but to answer the first question they don't use as much power as most other items on the market.....
to answer the second there might be an adaption that could be made but it is highly unlikely as it is using straight rf, mobile phones use bluetooth and wifi which is a data packet
