I need some help in diagnosing my multimeter. The Fluke 8846A is a benchtop DMM which functioned normally for about a year. Then it started giving me incorrect readings and in some cases no readings. Some instances I have tested are: resistance, shows correctly but only certain values in the Mohm range so precision is lost. I tried taking readings of a standard household outlet and in freq mode it switches back and forth from “overload” to correctly showing about 60hz, in VAC mode it shows .018 which is clearly wrong and something like .032 when the leads aren’t even attached. The temp mode doesn’t show anything when hooked to the appropriate TC. I opened it up and didn't see any obvious problems and both the replacable fuses are intact, it looks pretty sophisticated, ie: not too many parts I will be capable of replacing. My thought though is that since it is taking correct readings in some modes and maybe just the wrong decimal in others, it’s not too screwed up but Fluke wants $500 to repair it without even going through a diagnostic process! I can’t spend that kind of money so I was hoping someone in a forum would have an idea of what to do. Thanks in advance for any input!
